Help with new toilet flange
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by toiking, Aug 12, 2012.
  1. toiking
    toiking New Member
    Aug 10, 2012
    CA
    Hello everyone!
    My Fernco waxless started leaking after five years. I found out that the ABS flange was not level, below tile, and not anchored.
    I removed the outside 4" ABS flange with a drill. In order to install the new flange (inside) correctly I plan to pour cement for anchoring.
    1. Since the ABS turn is visible and only partially under concrete, can I pour concrete directly on top? Or should I put a layer of sand in between?
    2. For concrete, can I use Quickrete water-stop cement?
    3. Which flange type is better in the long run? Pure ABS or ABS/Stainless steel? Or should I use the gasket type since the drain may be crooked?
Similar Threads: Help toilet
Plumbing Forum, Professional & DIY Advice Renovation, Toilet Issues, Any Help Appreciated Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Help with toilet flange Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Toilet Leak- Need Help! *Video included* Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Help with toilet choices Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Toilet flange help please Sep 8, 2016
