Hi all. This is my first post. I purchased my first home a few years ago and it's starting to fall apart on me . The house has never been updated. A few weeks ago my tub drain started leaking through my dinning room ceiling. I opened a part of the ceiling up and saw that the leak is a hole in the lead train pipe. I plugged it with some rubber and some hose ties. Then this week 3 more holes 10 in away popped up and started leaking, I plugged them also. Now I need to replace it before it gets worse. My tub drain pipe goes down and under my tub for about 8ft then goes into my main cast iron drain that sits below my toilet then goes down my dinning room wall to the basement then out to the street.
In back of my tub in my 2nd floor hallway I have a small door to access my tub plumbing. I checked everything over and it seems to be very old. The tub has a drum trap. I've tried opening it months ago to clear a clog but couldn't budge it. Even with a little heat. So I'm figuring I should replace the lead pipe all the way up to my tub and replace the drum trap with a p trap. I've done some small plumbing before ( replaced water heater and sinks and faucets around the house) don't really have the means to bring someone in your do the work right now. My questions are about the direction of the pipes and the slope that I need to put on the pipe as it goes under my tub and over to the opposite wall. I also can't see a vent anywhere. I'm not sure what I can do about that. Thanks.
