SC Handyman
Junior Member
- Messages
- 8
- Reaction score
- 0
- Points
- 0
I've seen some postings about the pros and cons of using a check valve to solve pressure loss on the well side of the system. I installed a check valve about 2 years ago with no "apparent" problems. How can I troubleshoot this problem without pulling the pump unless the leakback is in the well pipe or pump check valve!
My system is a 350' submerged pump. The pump was replaced about 11 years ago because of a lightning strike. I noticed then that the well pipe was made up of sections of PVC. Would it be likely that the leakdown was coming from one of these PVC connections? I would like to defer the cost of this if possible until the next time the pump dies, if possible.
The other problem probably not related to this is low water pressure, especially in the upstairs bath. I have adjusted the switch pressure to 40-60 which has helped some, but can I safely go higher? Would a new diaphram tank help? The existing one is 22 years old. It's a 36 gal. X -trol. Diaphram pressure seems to be OK but does leak down a few psi over 6 mos. or so.
Any advise/suggestions much appreciated.
