LWPeterson
- Messages
- 2
- Reaction score
- 0
- Points
- 0
We have a leak that shows under the bowl on the floor. It started occuring suddenly. When the toilet is flushed the bowl starts to drain, and the tank starts refilling, then all of a sudden a large volume of clear water bursts from the left side, from between the floor and the bowl. We used a dye tablet in the bowl and none of the dyed water came out in the leak. We removed and reseated with a new wax ring, no change in the symptoms. What can be causing this?
--lwp--
--lwp--
