Help with Grohtherm 2000 19355
Discussion in 'Shower & Bathtub Forum & Blog' started by discjockeyr, Mar 13, 2009.
  1. discjockeyr
    discjockeyr New Member
    Mar 13, 2009
    Hi,
    Please i need advice regarding the above model.Note that is brand new (first installation). My problem is that by the spout always discharge water. When i select the shower the shower discharge normally and also some water discharged from spout. when i select spout the shower stops and the water came out normally from the spout. when i put the selector on the middle which supposed that stop the water from both outlets the spout continius to discharged some water. i have dissasemble 3 times and following the drawings to assemble it again but the same result. Please if anybody knows at least in which part of the mechanism maybe the problem i will apreciate it,
    Thanks in advance
  2. jadnashua
    I couldn't find that valve on their website. What are you using to divert the water from the tub spout to the showerhead? Note, on many of these valves, even though they have two outlets, you are supposed to plug one and onlyuse the other. Then, you use a twin-el (an elbow with two outputs) connected to the tub spout (assuming the spout has a divertor in it). A little more description or a picture of how it is put together should make it clearer. Do you still have the installation instructions? That should say how to connect outputs.
  4. discjockeyr
    Mar 13, 2009
  5. discjockeyr
    Mar 13, 2009
    ok,
    i have open again the unit.
    there are 5 plugs. 2 on the upper side one on the left (hot water inlet) one on the right (cold water inlet) and one of the bottom.
    The plumber connect the fixed top shower on the one upper plug and the hand shower on the bottom plug.
    The problem appears with the hand shower which is in the bottom plug. The water did not stop. How you can switch of the bottom outlet? the selector as i thing is switching between the two upper outlets.
  6. jadnashua
    I couldn't find anythings specific about which outlets are useable. Sounds like you'll need to call Grohe.
  7. discjockeyr
    Mar 13, 2009
    As i found on internet...seems that this model have 3 outlets. 2 on the top and one on the bottom. the 2 on the top outlets can be used with the valve/selector(aquadimmer) on the 19355 unit. the bottom outlet need an extra valve to switch the water on/off. so, thats meen tha my plumber make the installation wrong as he use the one on the top outlet and one on the bottom instead on using the 2 upper outlets.
Similar Threads: Help Grohtherm
Shower & Bathtub Forum & Blog Need urgent help with Grohtherm 3000 thermo fittings May 25, 2010
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Bathroom Remodel Help Jan 29, 2017
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
