Help with chronically clogged toilet
Discussion in 'Toilet Forum discussions' started by cgcg, Jan 30, 2008.
  1. cgcg
    cgcg New Member
    Jan 29, 2008
    Here's the problem. The toilet in my NYC apartment worked when I moved in, but eventually began clogging a lot, although not every time. Using a plunger worked some of the time, but the landlord eventually had to use an augur. After the clog had been cleared, he would test the flow of water through the toilet by sending a few wads of toilet paper down, which generally indicated a steady flow. The problem kept occurring, so his plumber replaced the toilet and a broken lead bend.
    As far as I could see, the new toilet is not remarkably different from the old one in design. In any case, the change did not produce better results. In fact, it's safe to say that the new toilet clogs almost every time it's used to expel solid waste.
    Because it doesn't take very long for the basin to back up after flushing, my feeling is that the clogs occur inside the toilet. The waste has trouble getting up from the bottom of the basin and over the lip of the trap or trapway (see pictures below). To be blunt, the kind of waste material involved doesn't look like it could be easily pushed around a curve.
    Will a pressure toilet and a broader trapway solve this problem? (Gerber says that some traps are as wide as 3.5 inches)
    I'm sure there's no way to tell for certain without examining the toilet and the pipes directly, but the landlord is all too ready to do nothing. I'd like to be able to suggest some options with a realistic chance of success. Will more force in the flush and more room in the trap help or is there something else you can suggest?
    Thanks in advance.
    Background details: I live in a five-story tenement building. There are four apartments on each floor. My apartment is one of the two rear apartments on the second floor. The bathroom is situated at the back of my apartment along the wall separating my apartment from the one across the hall. I believe the other apartment is the mirror image of mine, so the bathroom is also at the back along the interior wall. The landlord claims that the other apartment would experience problems similar to mine if there was a blockage further down the sewage line connected to my toilet.
  2. JimmyPipewrench
    JimmyPipewrench New Member
    Jan 30, 2008
    could be a venting problem. if the vent is clogged it will cause the water to drain slow if at all. like when you put a straw in a drink and hold your thumb over it. it wont drain till you take your thumb off and let air in.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    What brand and model of toilet is this new one?
  5. cgcg
    cgcg New Member
    Jan 29, 2008
    New Toilet
    The new toilet is a Gerber model, but no one can figure out which one--including the landlord. We tried looking outside and inside the tank, but there are no model numbers embossed or stamped as far as any of us could see.
    I can check to see if my landlord kept any records, but I suspect the new toilet didn't come straight from Gerber. In any case, it looks generally like the ones pictured if that helps any.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I doubt if your landlord would spring for a great toilet like a Toto Drake but you might talk him into springing for a cheap good flushing toilet like a Am. Std. Cadet 3
Similar Threads: Help chronically
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions Help: Trickle sound and smell from Cimarron Jan 21, 2017
