Help with big iron in well water!
Discussion in 'Water Softener Forum, Questions and Answers' started by ballvalve, Apr 18, 2014.
  1. ballvalve
    Dec 28, 2009
    northfork, california
    Have a water well that was clean and clear for 8 years, then iron started creeping in during the last 2 years. California drought era - perhaps due to water table [?] at time of drilling, had carefully chlorinated well and entire system to ensure against iron bacteria.
    Now have bank of 5- 5 micron WW house filters, plugging in about a month with reddish, very fine, rust looking powder. Still have iron in tubs and toilets.
    water test: Iron= 1.52, manganese=.48, PH=7.1, calcium=19
    Well feeds 2 rental houses with perhaps 6 or 8 people. Been providing enough water for years with a 1/2 hp pump and smaller pressure tank. But now iron issue is causing complaints with renters. My research shows that the PH is low for effective manganese removal? Seems like a very complex matter to spec the right components and not get fleeced, or have it all die in a year.
    Perhaps a very well done well and system chlorination would work? Might be just a iron bacteria issue.....
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I don't know what a WW filter is. I would think you need some kind of backwashing filter, and that would take the load off of your filter media that is getting clogged with ferric iron (rust). Pretty much any backwashing filter does that as a bonus. If you had the right media, I am confident that things would get even better. While I am not the person to recommend media, somebody will be able to help you with that.
    I use a Centaur Carbon filter for iron and sulfur quite effectively. I don't have the manganese, and my pH is higher than yours. But still, it matched what my well needed.
    I know some will recommend chlorination followed by a contact tank and then a backwashing activated carbon filter. That is a time-tested solution. Somebody may have something more compact to suggest. Dittohead has been teasing (as in the sense of a teaser in broadcasting) about some new media that will be announced soon. We will be eager to hear about that.
  4. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    I say your best bet is to install a chlorination/dechlorination system with a 120 gallon retention tank. A lot of the iron will be oxidized and settle in the retention tank followed by the carbon tank which will remove the rest of the iron.
Similar Threads: Help iron
Water Softener Forum, Questions and Answers Iron filter and softener selection help please? Dec 31, 2016
Water Softener Forum, Questions and Answers Need help With Softner/Iron System Mar 11, 2016
Water Softener Forum, Questions and Answers Iron Buster versus Water Right Impression Filter + Impression Iron Filter (pls help!) Mar 19, 2014
Water Softener Forum, Questions and Answers Help......Hard Water, Manganese and Iron Jan 6, 2014
Water Softener Forum, Questions and Answers Iron Removal Help Dec 22, 2013
