Help with angle stops under my sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bluetone78, Jul 29, 2009.
  1. bluetone78
    bluetone78 New Member
    Jul 29, 2009
    I need to replace some VERY old hardware going from my angle stops under the bathroom sink, to the faucet above. The angle stops are really old and aren't the standard 1/2" size, so I'm having trouble finding the right line to replace the old stuff.
    Obviously, the easiest thing to do would be to put in new angle stops, but plumber friend has advised against that, since the copper piping is so old and could easily snap. (I'm renting anyway, and just don't need that headache...)
    So I'm left with finding out what I'm supposed to do with this ancient, non-standard angle stop. I've discovered that the thread on the angle stop fit's a 1/2inch FLARE fitting exactly. The only trouble there is that the angle stop doesn't have the flare "nipple" (not sure what its called - the shape of the flare male end), so it doesn't seal.
    The way I see it, I have two choices: 1. find some kind of rubber washer or gasket to put into the end of the flare line which would seal it up. 2. find a regular, non-flare line that will fit the old angle stop.
    HELP! I'm in over my head... :)
  2. Sparty007
    Sparty007 New Member
    Jan 25, 2007
    Your other option is call your landlord and have him fix the leaky plumbing.
    I've never heard of old copper snapping? I'll wait for others to reply.
  4. Terry
    Aug 17, 2004
    A flared shutoff with copper coming out of the wall?
    Even I haven't seen that.
    Most of what I work with is 1/2" copper, which is 5/8" OD
    And for those, I use a comression fitting.
  5. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Like Sparty said, if its leaking, its your landlords job to replace it!
    Its probably 3/8 or 5/8" if its a weird size that wont fit 'normal' fittings.
    Take a picture beside an open tape measure. The best way to size and identify fittings on the internet!
  6. bluetone78
    Jul 29, 2009
    Your other option is call your landlord and have him fix the leaky plumbing. ​
    Part of the deal with this place, is that I take care of all this kind of stuff.
    I've never heard of old copper snapping? I'll wait for others to reply. ​
    The copper pipe is about 60 years old... it's pretty corroded...
    Even I haven't seen that​
    I know. It's pretty ancient stuff.
    Actually, it's not really 1/2" flare coming out of the wall. It's a regular IP style fitting. It just so happens that the thread exactly fits a 1/2" Flare line. I tried using a flare line (like for a gas dryer or something like that) but it doesn't seal because of the shape of the flare line fitting at the end.
    I was also thinking that it I could find some sort of solid, one-piece adapter to fit onto the angel stop, I could go from there. Does anyone know where I could get an adapter that has one side 1/2" FEMALE flare?
  7. bluetone78
    Jul 29, 2009
    as a total novice to in this sort of thing, part of the trouble I'm having is how these things are measure and labled. For example, a 1/2" flare fitting is actually 3/4" across the threading. 1/2" IP is about 7/8" across the threading.
    I guess what I need is something that is 3/4" across the threading (I just measured it) that has a regular IP style female end...
  8. bluetone78
    Jul 29, 2009
    I can't really get into the area where the angle stop is to take a picture. But I measured it and its 3/4" across - which is why it fits the threading of 1/2" flare I guess...
    CONFUSING!!
  9. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    So, as others have asked, why not have the landlord take care of it?
  10. bluetone78
    Jul 29, 2009
    Part of the deal with this place, is that I take care of all this kind of stuff. I'm paying very little rent
  11. Terry
    Aug 17, 2004
    Your next step are some decent pictures,
    Your descriptions are just confusing.
  12. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    almost sounds like stuff you would find in a mobile home.
  13. hj
    nut
    Your stop could have 7/16" compression threads which were available but seldom used. The supply lines for them are also rare, and if available will only be at a plumbing supply shop.
Similar Threads: Help angle
Plumbing Forum, Professional & DIY Advice HELP! how do you position a right angle fitting at 12 o'clock? Sep 7, 2013
Plumbing Forum, Professional & DIY Advice needs help in replacing angle stops Feb 5, 2012
Plumbing Forum, Professional & DIY Advice Angle Stop Valve Leak -- Help! Sep 28, 2006
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Yesterday at 3:53 PM
Plumbing Forum, Professional & DIY Advice Chipped shower tile....what to do help!! Monday at 6:09 PM
