I installed a Grohe Shower valve into a GrohFlex valve box.
This is a pressure balance valve with a select lever which you turn left or right to select between top shower head or hand shower wand.
After installing the valve and turning the water on I get a few water drips between the select lever and the water on/off lever. It only happens when turning the water on. The dripping does not happen when the water is turned off. There is no leaking where the valve slips into the valve box.
Does this mean the valve is defective ? Should I remove this from the valve box and put more o-ring lubricant and re-install?
Looking for suggestions.
