patty120499b
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I have a old hand dug well its about 15 feet deep with 3 feet of water. My pump is running non stop. I disconnected the water line and hooked up a garden hose thinking mabye i had a leak underground from the well house to our home but it still continued to run. I beat on the pipes with a pipe wrench and that seemed to stop it for a little bit then within a fe hours it was running non stop again. Right before winter i had to take the pressure tank out and clean it out because it was short cycling, when i would run water my lights would flicker then my pipes started baning but cleaning the tank seemed to fix that problem. my question is for the pump to continue to run all the time could this mean my pressure tank is clogged again. And if my pump isnt shutting off where is the water going that its pumping? My pressure hasnt changed any but my water has been cloudy. Another stpid question should my pressure tank have water in it or should it always feel emepty?
