It is a two resin tank non-electric setup. Water was coming out of the overflow.
I pulled the float and it seems to be sticking. It wasn't shutting off and there is a leak coming out of the side of the valve.
Do you know how Kinetico's work as far as the float mechanism? Is the float just for safety purposes or does it some how help change the valve in the head (senses back pressure when the float is in the up position)?
When I removed the line going to the brine tank, water was still coming out. I'm guessing the head is stuck in the fill position and the float did not stop the water from overflowing.
