Help! Tub won't turn off
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Portiadeans, May 24, 2014.
  1. Portiadeans
    Portiadeans New Member
    May 24, 2014
    Il
    Hi
    I desperately need some help. Daughter took a bath and now the water won't completely turn off. A steady stream about as thick as a toothpick is coming out, seems like cold water.
    It is a 3 -piece Danze roman tub faucet. Hubby is at the 500 so I am on my own for this one. I went online and figured out how to take the faucets handles off. I tried to tighten the brass fitting thing that was sticking up with a wrench as much as I could, but water is still coming out. I have shut off the well pump, but don't know what is wrong and what to do.
    Any suggestions?
    Thanks
    Beth
  2. jadnashua
    That valve could use a washer and a seat, or a cartridge. It depends on the model and the age. Worse comes to worse, you'll need to turn the water off for the house, say overnight, and turn it on during the day and waste that water.
    If you post a picture, or know the model of the valve you have, someone could advise what is required to fix it. In any case, before you take anything apart, you must turn the main water off (it's slightly possible, but uncommon, to have a shutoff for the tub underneath or behind it).
  4. Portiadeans
    May 24, 2014
    Il
    Thanks. Attached is a pic. I watched a you tube video and understand that I probably need to replace a gasket or cartridge. I couldn't figure out how to get the brass piece off to get to the cartridge. Is it one whole piece? In the videos, they seemed to be several pieces.
    I think the shutoff is in the crawlspace. I'd rather eat a bowl full of spiders than go in there. Okay, not really. The are both terrible. I think I am okay since I turned the well pump off.
    Beth
  5. jadnashua
    If I had to guess, I'd guess those use a cartridge, and not a washer and seat. In some wells, they can produce some sand and crud, and that can be tough on some valves. But, the pump being off, until the bladder tank runs dry, it will still flow, and, it will take it a bit to refill that tank when you turn it back on. But, leaving it off until you need some water means you'd probably keep it from turning on as often.
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Sometimes just working the valve back and forth will help to get the crud out, And open it wide open can help.
    Anytime you turn off your water, You should turn off your water heater first.
    Good Luck on your project, Welcome to Terry's Forum.
  7. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    "I couldn't figure out how to get the brass piece off..."
    You put a wrench on the brass nut right below the stem and unscrew it. It might help to use one wrench on the base above the porcelain and unscrew the nut with a second wrench.
  8. dj2
    dj2 Member
    Aug 13, 2013
    Winnetka, California
    I understand that this was hubby's last Indy 500. All troubles happen when he's away.
  9. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
Similar Threads: Help won't
Plumbing Forum, Professional & DIY Advice Help! Kitchen sink lock nut on drain flange won't tighten! Jun 16, 2011
Plumbing Forum, Professional & DIY Advice Help...Rusted fitting won't come off...Do I need a plumber? May 17, 2010
Plumbing Forum, Professional & DIY Advice Please help; new faucet won't turn off Oct 22, 2009
Plumbing Forum, Professional & DIY Advice my toe kick heater won't get hot? Help` Apr 27, 2008
Plumbing Forum, Professional & DIY Advice Help grohe rough in valve won't turn off May 23, 2007
