Help solve an "argument" about a DPST thermostat for my ceiling heat?
Discussion in 'HVAC Heating & Cooling' started by Blind Frog, Aug 23, 2012.
  1. Blind Frog
    Blind Frog New Member
    Aug 23, 2012
    Western Ohio
    My electrician buddy was admiring my new Honeywell LineVolt Pro 8000 (TL8230A1003) as we prepared to install it. This is a DPST model (two red/two black). I told him I would like to find similar models for my SPST units (One red & one black wire) for my smaller rooms. He said that since I got the thermostat at a great price, I should just do all the rooms with the same DPST model. He said I should simply pigtail both reds and both blacks (Line & Load) and then tie into the existing wiring. I told him this either could NOT be done or it would shorten the life span of the stat. He says I am an idiot. :p We have a pitcher & pizza riding on it.
  2. jimbo
    jimbo Plumber
    San Diego, CA
  4. Blind Frog
    Aug 23, 2012
    Western Ohio
    jimbo - HEY!!! At first I was worried you were saying he was right and I was wrong...then I noticed you are a PLUMBER and not an electrician, so I know you are all wet and your answer can be flushed down the drain!:rolleyes:
  5. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    Check out this image and you surmise who is incorrect :)
  6. Blind Frog
    Aug 23, 2012
    Western Ohio
  7. jadnashua
    I do not agree with the drawing of the DPST switch above! A double pole (two paths), single throw (essentially an on/off switch) is commonly used to break BOTH leads of a 240vac device...it is essentially a two pole on/off switch. It is safer since it actually removes power entirely from the device, whereas a SPST switch on a thing like a 240vac heater does stop it from operating, but there's still voltage applied to the device. If it developed an internal short, or you touched something in it and were connected to ground, you could fry yourself. SPDT and DPST are reversed in the drawing.
  8. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    Yep. These look better. Copied that image from google...
    http://www.kpsec.freeuk.com/components/switch.htm
  9. jimbo
    jimbo Plumber
    San Diego, CA
    I was a Master Chief Electronic Technician in the Navy, couple that with on a submarine everyone learns about everything, I feel eminently qualified to comment on switches!
Similar Threads: Help solve
HVAC Heating & Cooling Reme Halo install help Mar 9, 2017
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling Help! - new system is not cooling adequately Jul 14, 2016
HVAC Heating & Cooling Looking to buy 2 stage 17 seer AC Need Help Jul 5, 2016
HVAC Heating & Cooling Mini-Split help Jun 10, 2016
