Help: Shower faucet and valve
Discussion in 'Shower & Bathtub Forum & Blog' started by stautxie, Jul 13, 2013.
  1. stautxie
    stautxie New Member
    Jul 13, 2013
    Orange County, CA
    Dear all,
    I am stuck while remodeling my bathroom and want to seek your advice.
    1. I want to change shower valve handle and try to avoid soldering. I have already removed the original handle and plate but stuck at the cap. I think I can screw in a replacement handle, e.g. Pfister's universal handle, if I can get rid of the original cap. I cannot unscrew it with a plumber's wrench. Any suggestions?
    2. I am trying to replace the shower head as well. After stripping the old head, I am stuck with the spherical end that does not come off at all. Any thoughts on it?
    Thank you all for your attention.
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    The rule of thumb is that if you open the wall you change the valve. There is no such thing as a universal handle, yours looks like it takes a Delta. Try any handle you get before you close the wall. You will need to use a new shower arm if you are changing the head.
  4. Terry
    Aug 17, 2004
    It would be regrettable if the valve isn't replaced at this time.
    New ones are pressure balanced, and it's getting harder and harder to find parts for the old stuff.
    You will need a new shower arm without the round knob end. It should have 1/2" pipe threads on both ends.
  5. hj
    You have a Delta valve, and since it is the very first 'generation' there is NOT handle except the lever one with a ball on the end which will work with it. To replace the shower head you have to also replace the shower arm. There should be three small tubes joining the front and back parts of the valve, and if you are not careful you will twist them off and then you will HAVE to replace the faucet.
Similar Threads: Help Shower
Shower & Bathtub Forum & Blog Shower Diverter Help Yesterday at 11:00 AM
Shower & Bathtub Forum & Blog Help identifying shower handle extension Saturday at 9:13 PM
Shower & Bathtub Forum & Blog Need help in identifying shower faucet Thursday at 6:36 PM
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
