help! Running toilet won't stop!
Discussion in 'Toilet Forum discussions' started by icer123, Oct 20, 2007.
  1. icer123
    icer123 New Member
    Oct 20, 2007
    I have this very annoying constant running water problem with my toilet that just started today. I've dealt with these in the past but they usually had to do with adjusting the chain or the floater thing. In this case, the water won't stop, even temporarily no matter what I do. Even if I shut off the toilet water supply, it still runs!! I have to shut off the main water supply to my entire house to keep the toilet from running.
    Please Help me!
  2. Terry
    Aug 17, 2004
    You may need to replace a flapper.
    If the water is not going over the overflow tube, the flapper is leaking.
    The toilet will continue to fill.
    If the water is going over the overflow tube, then the fill valve is not shutting off. Then the fill valve may need repair or replacement.
  4. icer123
    icer123 New Member
    Oct 20, 2007
    The water is going over it so I'm pretty sure the fill valve is not shutting it off.
    But the thing that bothers me the most is that the water still fills up even when the toilet water supply (that comes out of the wall near the floor) is turned off. I didn't think that was even possible.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Either your stop valve is leaking or you don't have it shut off all the way.
  6. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    That happens often. I would replace the shut off next to the toilet.
  7. icer123
    icer123 New Member
    Oct 20, 2007
    I figured this should be replaced.
    Is it possible that I am experiencing two separate problems? One is the water supply valve leaking water out and the other is the fill valve not stopping the flow into the toilet?
  8. jadnashua
    Yes, sounds like you have two problems. If it is a farily standard toilet, replace the fill valve, the hose to it from a new shutoff. Then put in a new flapper, and the toilet controls are essentially new. Should last a long time. Use a 1/4-turn shutoff, and it should still work when this happens again. Those with washers ususally fail over the years, and then don't work when you need it to.
Similar Threads: help Running
Toilet Forum discussions toliet running out of the blue / help please Feb 27, 2013
Toilet Forum discussions toto guinevere running constantly, help! Jan 24, 2011
Toilet Forum discussions Trying to help a friend with a running A.S. toilet Jan 18, 2009
Toilet Forum discussions Help with water running Oct 12, 2007
Toilet Forum discussions please help non-plumbers with running toilet Feb 24, 2007
