mrs.fixit
Help! I'm replacing lead drain lines in my bathroom in a house built in 1960. After much struggle, I finally removed a galvanized elbow from a fitting connected to the cast iron ideal bend with a 36†wrench. Unsure what material the threaded nipple was made of, I thought I'd be safe and remove it too and use male pvc adapters to run pvc drain lines to connect both the bathtub and sink drains to the ideal bend.
In trying to remove the threaded nipple, I crushed it-- but it still won’t back out of the cast iron. In hindsight, I probably should have left the nipple and just used a mission-type coupling, but here I am now. I am worried that if I keep trying with the pipe wrench I’ll shear it off. How can I remove the nipple? I am considering using a sawzall to make several slits in the nipple up to the bend and trying to break out the pieces by grabbing them with channel locks. Is that a good/bad idea? Other ideas on how to get it out without damaging the bend? I'd appreciate any ideas.
Here are some pictures:
