Patricia T
- Messages
- 8
- Reaction score
- 0
- Points
- 0
Hello,
I'm new here and hope to find some advice in selecting a new gas H20 heater. The current installation is a plain-wrap variety of the contractor, 17 yr. old, single story, single family home of 2700 sq. ft., 2 1/2 baths. Due to some corrosion and the blanket, I cannot read the capacity but am guessing it's in the ballpark of 40 gal. I've also got a circulating pump w/timer installed due to length of the house and distance from garage (where installed) to the opposite end.
I generally am thorough in research but am not familiar with today's H20 heaters at all. I prefer quality without overkill and value for the $$. I'm checking with the folks here first to escape a sales pitch from local retailers as well as avoid any consumer pitfalls.
More info: I am single and spend about half of the year traveling on business, so there is not a need for a high recovery model or larger (than current) capacity. The water in my area is hard and there is rust and corrosion evident under the blanket. Recently I've discovered signs of an occasional small wet spot from the blanket. It's time to replace.
Can anyone offer suggestions as to manufacturer and models that I might consider? As mentioned, I prefer quality with value for the $$. Also, are there any other preventative measures that should be considered as a result of the hard water in my area?
Any advice would be most appreciated.
Thank you!
-Patricia
Thank you!
-Patricia
