Help Programming a Fleck 7000 SXT
Discussion in 'Water Softener Forum, Questions and Answers' started by batboy, Jun 21, 2010.
  1. batboy
    batboy New Member
    Jun 21, 2010
    MN
    Details on the machine: 64,000 gr capacity, 2.0 cu/ft resin (standard resin)
    I need some help setting up the machine to give me good salt efficiency. I probably won't be needing the whole 64k capacity right now.
    I have 3 adults in the home using about 75 gal/ per day so that's 225 gal.
    Hardness is 22 and I would like to regenerate every 9-10 days. I was thinking of setting the capacity of the machine at 40k. Am I thinking of this correctly?
    Here is a link to the install guide and settings that I used for programming:
    http://www.qualitywaterforless.com/v/vspfiles/downloadables/fleck/70SXTINS.pdf
    Current settings:
    DF: GAL
    VT: St2b (Standard Downflow/Upflow Double Backwash)
    CT: Fd (Meter Flow Delayed)
    C: 64k (capacity)
    H: 22 (hardness)
    RS: SF (Percentage Safety Factor)
    SF: 20 percent
    DO: 10 (Day override)
    RT: 2:00AM
    BW: 10 mins (back wash)
    BD: 60 mins (brine draw)
    BD: 40 (salt time setting)
    RR: 10 mins (rapid rinse)
    BF: 10 mins
    FM: t1.2 - 1.5'' Turbine Meter (7000 default)
  2. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    I would recommend you go no more than 8 days between regenerations. This will also allow you to get better salt efficiency.
    You need to know the size of the Brine Line Flow (BLFC) control on your control. There is usually a sticker on the back of the unit that identifies the size installed. I note the instructions you posted (the link) speaks of a .25 gpm BLFC. The amount of water added during brine fill determines the amount of salt and the capacity setting you should use. The practical max capacity is 60K with a 2 cubic foot unit and to get that capacity you need to regenerate with 15 lbs of salt per cubic foot (30 lbs total). Each gallon of water added during brine fill dissolves 3 lbs of salt. so to get 30 lbs you need 10 gallons of water. If your BLFC is .25 gpm then you would need 40 minutes of brine fill.
    Dre you on city or well water? Is there any iron in the water--if so did you factor it in the hardness reading--each ppm of iron adds 5 grains to get compensated hardness.
    If you were to set it up for an average 8 day regeneration, using your figures, your desired capacity would be 22 x 225 x 8 ~= 40,000 grains. To get 40,000 grains you need 6 lbs salt per cubic foot or 12 lbs and that takes 4 gallons of brine fill water--so if your BLFC is .25 gpm that would be a setting of 16 minutes. I would set the safety factor to 15 percent with these settings along with an 8 day override.
    Also the second BD should be the second backwash and a relatively short time--certainly not 40 minutes.
    We can talk about specifics once you answer the questions above.
  4. batboy
    batboy New Member
    Jun 21, 2010
    MN
    The sticker on the back of the valve says .25 blfc. There is no iron in our water. This is city water. So for the 16 min setting, I would enter that in the length of the brine refill cycle correct?
  5. Bob999
    Jul 4, 2009
    Pennsylvania
    I have entered recommended settings above in red.
    If you have been operating the unit with the settings you had posted the resin has probably been partially discharged and to bring it back to fully charged and get best performance you should do two regenerations with 30 lbs of salt each --a 40 minute brine fill. Ideally there will be no water use between the two regenerations and you need to allow about 3 hours between the end of the first regeneration and the start of the second regeneration for the salt to dissolve and create a full strength brine solution. So if you initiate an immediate regeneration early evening then you can initiate the second (delayed) regeneration as you retire for the night.
  6. batboy
    batboy New Member
    Jun 21, 2010
    MN
    Thanks for the pointers Bob. I changed the draw time to 40 min and did 2 regens. When I did this though, I changed all my settings to what you suggested and just changed the 16 - 40 for the draw time. I hope that was correct! I'll keep you updated on how the water feels.
  7. Bob999
    Jul 4, 2009
    Pennsylvania
    That should be fine so long as there was 3 hours from brine fill to start of regeneration for each of the two regeneration cycles.
  8. Gary Slusser
    Retired
    Over the last 6.5 years I've used 2 hours and not had problems. A customer did salometer tests before and during regenerations for months with both Pre and POST brine refill at 2 hours and couldn't find a problem.
    Other dealers call for 4 hours minimum.
    BTW Batboy, I wouldn't program it the way Bob says. If you look at 15% of 40K, you probably won't get 8 days between regenerations and there is no need for that reserve. But try it and see how it goes.
  9. batboy
    batboy New Member
    Jun 21, 2010
    MN
    Well Gary, more knowledge is always better. How would you suggest to program this?
  10. Gary Slusser
    Retired
    Take the 15% off the 40K and see what numbers you come up with and how many days between regenerations.
    Plus you are using 75 gals/day/person and I would use 60. I don't agree with 5 gpg for each ppm of iron, use 4. I also don't agree with the number of minutes for the cycle positions.
  11. batboy
    batboy New Member
    Jun 21, 2010
    MN
    What settings would you recommend using?
  12. TWEAK
    TWEAK New Member
    May 17, 2009
    Bay Area CA
    I had some of the guys help me with programming my 7000SXT a few months ago.
    The experts here will give good advice but I do have one suggestion. Gary Slusser recommended to me that I use the DFF (downflow-fill first) mode rather than the default DF mode. DF refills the brine tank after the regen, letting is set until the next regen. DFF refills the brine tank at the start of the regen, and allows time for the salt to dissolve before getting on with the regen. Gary claimed that DFF helped keep the brine tank cleaner and reduced the chances of salt bridging. There was some debate about this -- others felt that there was no effect on salt bridging or brine tank cleanliness.
    I tried both modes and my experience supports Gary's choice of DFF in terms of salt bridging. I haven't been able to confirm the cleanliness argument, but here during warm weather I have definitely seen salt bridging in the DF mode. I believe that what is happening is that, in DF mode, some of the water evaporates during the week between regeneration. The brine is a saturated solution, so when you lose water salt precipitates out. This salt ends up causing the bridge. It's easy to break up but annoying. On the other hand, if you use DFF as Gary suggested, the brine isn't sitting around all week - only a couple of hours. It therefore doesn't evaporate away any water and so no salt precipitates out to form a bridge. I'm not 100% sure that this is the mechanism but it makes sense... and since changing to DFF, I see no salt bridging no matter the weather.
    I also want to comment on the calculation. We seem to use 60 gal per person per day. I think this is a good number when you have at least a few people in the household. But in my case I am down to just one person (me) and the water consumption is definitely higher than one person. The reason is that with one person, your water use (no matter how hard you try) just isn't as efficient. Every shower and most of the sink uses start with dead cold water in the pipes, causing you to run the water a bit. And despite your best effort you end up running more partial laundry loads and even are more likely to run more partial dishwater loads. So I would recommend using the 60 gal figure for starters, but keep an eye on it and be open to jacking up that per-person figure if there are less people. I use 85 gallons with one person and while that may sound high, it's the right number for me... and I'm NOT an extravagant water user!
  13. Gary Slusser
    Retired
    I think bridging happens with post refill due to the water being wicked up into the salt above the water line. With a tight salt tank lid there can't be much if any evaporation of water because there is no air flow through the tank. I think the dry salt sucks up the humidity.
  14. TWEAK
    TWEAK New Member
    May 17, 2009
    Bay Area CA
    Interesting thought, Gary. Seems like if the culprit was water wicking, it would be just as likely to happen in two hours of a pre-fill cycle as it would in a week using post refill, no?
    I agree you don't get a lot of evaporation with the lid on the tank. But you're bound to get some evaporation. Those salt tank lids are not all that good. It would be fairly easy to the actual amount of loss over a week... sounds like a good science project!
    Hey here's another question for you all. I'm using about 1/4 of my softener's capacity, with the salt dose adjusted down due to the decreased usage. Is it a good idea to run a full regen with 20+ pounds of salt every so often or would this be a waste?
  15. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Why again are you running at 25% of what the system can do?
  16. TWEAK
    TWEAK New Member
    May 17, 2009
    Bay Area CA
    I bought the system sized for more people living here. One kid got married, one went off to live at school, one got a job out of the area.... Now it's just me.
  17. Gary Slusser
    Retired
    It's kinda like running your vehicle at say 1500 rpm instead of up against the red line but....
    Tell us why you suggest running it at a higher capacity and what the benefit is to him.
    Tweak, wicking takes a fair amount of time because the lower salt must become fully wet before wicking can happen. And salt lids fit so tight they are damned near hermetically sealed. Wicking would only happen with block or pellet type salt.
  18. Akpsdvan
    Dec 29, 2009
    Alaska
    So a 44k unit , that is 12lbs of salt for the 2 cubic foot of resin... and you are running at ?lbs and ?capacity
    Under running on a system is not really good on the resin, it needs to be used,, ie charged and uncharged ..
    One way is setting the capacity and the salt setting and a def day of say 15.. that way if there are people over then the meter or if just you the days will trip it.
  19. Gary Slusser
    Retired
    I'd like to see the stock regular mesh spec sheet from a resin manufacturer that supports your 44K @ 12 lbs claim. Or where a resin manufacturer says to run resin at max capacity and that to run it at less is bad for resin. BTW, a 2.0 cuft softener is mistakenly called a 64K; the true K is 60K @30 lbs. And setting the capacity so the unit regenerates like every 7-9 days means the resin is regenerated (with less salt) based on actual capacity used, more frequently than every 15 days (requiring much more salt).
  20. TWEAK
    TWEAK New Member
    May 17, 2009
    Bay Area CA
    My unit is 1.5 cu ft of resin, which I understand is "the" amount for a 48k (really 44k ). As Gary points out, the "advertised" numbers seem to frequently be higher (i.e., 48k instead of 44k, 64k instead of 60k etc).
    My understanding is that it isn't recommended to go out to 15 days between regens.... several folks here recommend 7-9 days. I don't remember the exact salt dose without referring back to my notes on the programming but it's around 5 pounds more or less.
    Question is really... is there any reason/advantage to every so often (say, every couple of months) regenerating with a higher salt dose?
  21. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    Maybe I'm confused here, and maybe you meant to word this differently but as it stands it makes no sense at all.
Similar Threads: Help Programming
Water Softener Forum, Questions and Answers Fleck 5600sxt programming help Tuesday at 7:44 PM
Water Softener Forum, Questions and Answers Programming help for a Fleck 5600SXT 64K system Mar 6, 2017
Water Softener Forum, Questions and Answers Fleck 7000SXT programming help for efficiency. Aug 30, 2016
Water Softener Forum, Questions and Answers 7000sxt programming help May 20, 2016
Water Softener Forum, Questions and Answers First time with a water softener, help with programming Jan 1, 2016
