Help, plz! Copper pipe question.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seanc, Jul 12, 2005.
  1. seanc
    seanc New Member
    Jul 12, 2005
    Hi there,
    i just finished the plumbing for the basement, everything went really well and looks fantastic. I put up the drywall before finding the answer to this question and need to figure this out before i finish painting it.
    I am running the copper pipe through mainly wooden studs, it does however pass through some metal studs. I didnt use nylon gromets around the holes the copper is running through. Is this a problem? Do I need to pull the drywall down and redo this? I'm not sure if copper and metal studs will create an electrical charge and cause the copper to corrode.
    Thank you for your time!!!
  2. Terry
    Aug 17, 2004
    You don't want the copper touching the metal studs.
    Now is the time to fix it.
    They make plastic inserts that fit a 1-3/8" hole and they have winged clips that can be screwed in.
  4. hj
    pipe
    The problem is not any electrical charge. You do not want the copper tubing rubbing against the steel which will wear a hole in the pipe.
  5. seanc
    seanc New Member
    Jul 12, 2005
    well, I anchored the plumbing down with copper straps such that there is little to no chance of the pipes rubbing against the metal studs. Is this the only concern? I do not have to be worried about chemical/electrical reactions between the copper and the metal in the studs?
  6. hj
    copper
    If there were a reaction, which there will not be, the copper would eat the steel away, not the other way around.
  7. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
  8. srdenny
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
  9. dx
    dx General Contractor
    Jul 4, 2005
    General Contractor
    Michigan
    Sean,
    The issue is galvanic corrosion. Do a Google search and learn for yourself. If you have high relative humidity and the copper touches the galvanized studs, the zinc will be consumed first, and quickly (small relative anode area). Then the steel. The copper is the more noble of the 3 metals, so will not eat away much. You will likely end up with rusted studs. The process may stop when enough of the stud is eaten away to break contact with the pipe. If relative humidity is very low, nothing much is likely to happen.
    If it were me, I'd fix it.
Similar Threads: Help Copper
Plumbing Forum, Professional & DIY Advice Help with Copper Pipe Support Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice IKEA, Help connecting with 1-1/4" copper stub out Aug 17, 2016
Plumbing Forum, Professional & DIY Advice Soldering brass to copper help....PLease! Nov 25, 2010
Plumbing Forum, Professional & DIY Advice 1 1/2 copper to PVC help Jun 26, 2010
