Help plumbing new 1/2 bath in basement.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Eric Backlund, Jun 27, 2014.
  1. Eric Backlund
    Eric Backlund New Member
    Jun 27, 2014
    Colorado
    We are adding an additional 1/2 bath to our basement as well as moving the laundry. I have the trenches mostly finished. We are required to have a backwater valve before any other drain lines, so we are going to put it inside the cabinet in the bathroom. We will need drain lines for the lav sink and for the washing machine. The distance is too far to hook into the existing vent system so we will be using a studor vent (which I have already cleared with the inspector).
    I need help figuring out how to design the system, particularly where the vent lines need to be in relation to the WC and where to reduce from 3" to 2" (or 1 1/2" if allowable) to fit inside the wall between the bathroom and laundry room. The back wall of the bathroom and laundry is a foundation wall with a footer underneath. I would prefer not having to cut into the footer, that was the reason for having the 2" line in the wall between and draining the washer and lav to that point. I am in Colorado if that make any difference.
    I am including a sketch of the trench and the location of the bathroom as well as pictures of the area as it is now. Any help is greatly appreciated. Thanks in advance for the help!
  2. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    What's the purpose of the black plastic , corrugated pipe in the last photo?
  4. Eric Backlund
    Jun 27, 2014
    Colorado
    black plastic
    That is french drain for the sump system. It is laid around the perimeter of the foundation, then connected to the sump pit.
Similar Threads: Help plumbing
Plumbing Forum, Professional & DIY Advice Laundry Room Renovation Plumbing Help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice New Construction Plumbing Help Dec 7, 2016
Plumbing Forum, Professional & DIY Advice 1st post - having bathroom remodeled. Need plumbing help Nov 21, 2016
Plumbing Forum, Professional & DIY Advice Help with basement bathroom plumbing design Nov 16, 2016
Plumbing Forum, Professional & DIY Advice Under slab new plumbing help - venting/santee Aug 1, 2016
