HELP PLEASE! What will I need to pull a pump from my well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Dan K, Jun 27, 2007.
  1. Dan K
    Dan K New Member
    Jun 27, 2007
    I need to pull the pump from my well because of a leak or faulty check valve. What will I need for this or is it best to leave for the Pro's?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    It depends on how deep it is. How deep is it?
  4. Dan K
    Dan K New Member
    Jun 27, 2007
    116 feet deep
  5. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Is that where the pump is hanging or is that the well depth?
    bob...
  6. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    You need a way to lift it, and at least 2 large pipe wrenches, a pipe brake to keep it from sliding into the hole, at least 2 large sets of vice grips as safety catches, about 3 rolls of black tape, a knife, and a large wrench to slide the pitless guts away from the casing. The pipe sections are 20' tall. Hand lifting a 100+ footer is going to be very difficult at best.
  7. Dan K
    Dan K New Member
    Jun 27, 2007
    Thanks for the info. I think I will call the well company.
  8. Cass
    Cass Plumber
    Nov 12, 2005
    If it is black polly well pipe I have pulled them out by hand 135' deep.
    It takes 2 guys.
  9. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    we have a local driller who will set poly pipe as deep as 500 feet. talk about a lot of work to pull this pump!
Similar Threads: HELP PLEASE
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Wednesday at 9:38 PM
Pumps and Tanks Well Forum & Blog. Water is life. Need help ID'ing the well/casing Please! Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help With Pressure Tank Selection Needed....Please Dec 1, 2016
