Help Please, Thermal Expansion Control Valve
Discussion in 'Water Heater Forum, Tanks' started by rhumbaclave, Nov 16, 2009.
  1. rhumbaclave
    rhumbaclave New Member
    Nov 16, 2009
    Pueblo
    Hi,
    I love this forum and it has helped a lot. We have purchased a new house and I have had some problems with the hot water heater. It is a 2002 State Select Power vent. It was a REO and was winterized when we bought it so when we first fired it up the T&P was leaking. I replaced it and all was well...so I thought. Friday the Thermal Expansion Control Valve was not just dripping put trickling steadily, I replaced it but it has not stopped the problem. It is leaking quite a bit.
    Is this a pressure problem or is it because the hot water heater is set to high? Do we need an expansion tank?
    Thanks so much.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If you have a PRV you need an expansion tank.
    John
  4. rhumbaclave
    Nov 16, 2009
    Pueblo
    Thanks John. I just realized I messed up my definitions. It was my T&P leaking not a PRV, I do not have a PRV. Sorry.
  5. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    Just to further muddy the waters: PRV for plumbing is not the same as PRV for industry/process engineering. PRV typically referrs to a pressure relief valve, but for home plumbing it refers to a pressure regulating valve. The T&P is both a thermal and pressure relief valve.
    There is probably nothing wrong with the PRV. This is a thermal expansion problem and will require a small thermal expansion tank. Otherwise, the T&P will relieve everytime the system pressure hits 150. You can put a $10 test gauge on a hose bib or other tap to confirm the cycle.
Similar Threads: Help Please
Water Heater Forum, Tanks 50 gal electric help me please Jan 26, 2017
Water Heater Forum, Tanks Water Heater wiring, Please help Feb 22, 2015
Water Heater Forum, Tanks need water...help! Please.... Jun 29, 2013
Water Heater Forum, Tanks A. O. Smith won't fire... please help! Dec 6, 2011
Water Heater Forum, Tanks New Install Help Please Nov 9, 2011
