Help on DWV Diagram
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Drewski123, Oct 25, 2011.
  1. Drewski123
    Drewski123 New Member
    Aug 4, 2011
    Seattle
    Can the tub drain use the DWV 3" vent? The distance between the tub and the DWV 3" vertical part is less then 15". Or, it has to vent using its own 1.5" vent, and then the 1.5" vent would merge with the 3" vent in the attic?
    Thanks,
  2. Terry
    Aug 17, 2004
    You can't run a toilet down a tub vent in Seattle, or anywhere.
    You will need to run a 1.5" vent between the tub p-trap and the stack and then either go through the roof, or revent at 42" above the floor.
    [​IMG]
  4. Drewski123
    Aug 4, 2011
    Seattle
    Thanks Terry. My initial plan was to run the 1.5" vent, but wanted to make sure.
  5. hj
    Just "running" a 1 1/2" vent is NOT enough, it has to be run CORRECTLY.
Similar Threads: Help Diagram
Plumbing Forum, Professional & DIY Advice [3D diagram] Basement Remodel Bathroom Help (add shower) Dec 31, 2014
Plumbing Forum, Professional & DIY Advice Riser Diagram help - NJ NSPC 2009 attic bath Mar 6, 2012
Plumbing Forum, Professional & DIY Advice Basement Plumbing Diagram Help May 11, 2010
Plumbing Forum, Professional & DIY Advice Plumbing Diagram Help Apr 28, 2010
Plumbing Forum, Professional & DIY Advice Plumbing sink with no overflow. Please help Thursday at 9:02 AM
