Help!! new toilet doesn't cover
Discussion in 'Toilet Forum discussions' started by IPWinsor, Jan 5, 2008.
  1. IPWinsor
    IPWinsor New Member
    Oct 4, 2007
    Hope all the good experts here are online today.
    I finally decided to have a go at replacing my downstairs toilet today.
    What I discovered is that the previous owner of the house had laid ceramic tile around the toilet, then filled in the gaps with grout. The toilet was firmly cemented to the floor.
    I had to use a Dremel tool to cut the grout around the toilet and a chisel and hammer to chip it away to get the toilet off the floor and flange.
    Once the toilet was removed , I was left with a gaping hole in my floor. See attached picture. Its about 3/4 to and inch deep in front of the flange.
    Also, the flange is not level. Its level with the floor in the back and on the right side, but about 1/4" below in the front and on the left side.
    I test fitted the new Cadet 3. Thankfully, its longer than the toilet it replaces, and sits on tile front and back. I will need to shim it on the back right for stability, but it will work.
    Questions:
    1) Should I fill to hole in front of the flange to be level with the floor? What with? Quick dry cement?
    2) Will the unlevel flange be an issue. I test fitted a 1/4 flange extension, but I think it would be too high in the back and on the right.
    3) any other ideas or suggestions welcome!
    Ian
    Milton, Canada
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Unless you want to replace the floor,set toilet and use sanded grout to fill in
    voids.
  4. IPWinsor
    IPWinsor New Member
    Oct 4, 2007
    Nope, don't want to replace the floor.
    Thanks
  5. IPWinsor
    IPWinsor New Member
    Oct 4, 2007
    What about the uneven flange? Will the wax gasket fill this gap?
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    you can use an extra thick wax seal
  7. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    The slant in the flange is not really anything to get too worked up about. A normal wax ring should do fine, but using the extra thick version is worth it.
    If you want to fill in the gap on the floor, you may as well try to match the tiles and replace the cut ones surrounding the flange after removing the old ones. But any kind of floor patch compound or mortar should do fine.
    Have you looked into putting in a skirted toilet? Perhaps one of the skirted Toto models will have a wider and longer base which will cover up the flooring mess, and the unift flange will solve your uneven flange problem.
  8. IPWinsor
    IPWinsor New Member
    Oct 4, 2007
    Thanks.
    I already bought a Cadet 3, so that's the toilet I am going with.
    I filled the hole with concrete patch. Any bit of concrete that you can see after the toilet goes on will get a dab of white paint to hide it.
    This doesn't have to be a beautiful install; I will just be happy to have a toilet in the BR that does not backup or have the flapper stick constantly like the one that got replaced did.
  9. Terry
    Aug 17, 2004
    You're right, why go with a bigger base that hides the gaps in the tile.
    It won't matter where it's is anyway.
    But if it were my house.............
  10. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Why wouldn't you use a flange spacer ring to get the flange up to the right height so it won't leak and make your bathroom smell like poo? Why patch the floor and install a toilet that covers the mess? All that when you can have a toilet that looks and smells like poo!
  11. Sofa King
    Sofa King New Member
    Jul 10, 2007
    My Guinevere is a BOB, (big ol' bitch) and would fill that measly hole no prob. You need a Guinevere...Life's too short to be cheap.
    Sofa King
    PS I haven't cleaned my Guinevere in three months and still looks like new thanks to Sani Gloss & Terry Loves Plumbing board.
    I love this toilet so much I'm fixin' ta marry it.
    [​IMG]
    Toto Guinevere, the large base covers up where the old toilet imprint sat.
  12. IPWinsor
    IPWinsor New Member
    Oct 4, 2007
    The job went well. Its flushes fantastic and did not need shims to make it stable. The wife is pleased, and at the end of the day, that's what's most important! ;)
  13. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I can't believe the number of floors I've seen like that. I guess tilesetters (pro or DIY) are terrified of pulling the toilet and doing it right. That should be required for the journeyman floor installer's license...
Similar Threads: Help toilet
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Help finding a specific toilet Jan 17, 2017
Toilet Forum discussions Help! Toilet makes weird noise every 3-15 seconds after hours of not being flushed Jan 11, 2017
Toilet Forum discussions Please help! Toilet is frustrating me! Dec 27, 2016
