Help needed with galvanized pipe!!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by miles, Sep 17, 2005.
  1. miles
    miles New Member
    Sep 17, 2005
    In a bathtub/shower remodel, I was trying to replace the 3/4" galvanized end to 1/2" copper reducer from the galvanized pipe coming from the hot water supply when the galvanized pipe broke right above the threads of a rusty T. The pipe to the left of the T comes from the Hot Water Tank & is undergound & the pipe to the right of the T supplies downline & is also under concrete. There is no crawl space. House is on a concrete slab. The work area I have to work with was previously dug out (by the previous owners) & there may be just short of a foot of galvanized pipe partially exposed on the right side of the T & even this is bordered by concrete on the edge closest to the exterior wall. Is there any way to re-route to avoid having to deal with the pipes under the concrete? As you can probably tell I'm an amateur. Is there a way to "plug" up the hole? Even if the whole pipe was exposed, I still wouldn't know the best way to proceed. If I have to get to the pipes, how would you recommend I proceed? If hiring a plumber is my best bet, I guess I'll have to bite the bullet & pay the costs.
    Any help would be greatly appreciated since we don't even have water at this point.
  2. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    Bite The Bullet
    call a plumber. think of your family
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Post a picture or two and I'm sure someone can recommend an option or three for you.
    Thx
    Jason
  5. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    Old galvanized is probably the worst type of pipe to work with. You cannot solder it, so you have to get to good threads. You can try very carefully cutting and chiseling out the remaining stub in the T. This is not easy work and may not even be possible given the rust you have already encountered. How old is the house?
Similar Threads: Help needed
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice DWV Layout Help Needed Nov 3, 2016
Plumbing Forum, Professional & DIY Advice Help needed Sep 27, 2016
Plumbing Forum, Professional & DIY Advice New Tub Installation - Drain/Overflow Help Needed Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Help needed ASAP in bath remodel, DWV installation/replacement Nov 19, 2015
