I am at my wit's end and could use any suggestions possible. Based upon much research, including great help I obtained from the existence of this forum, I purchased a Toto Guinevere. Unfortunately, I have had nothing but trouble with it and it continues being a problem. I have been in touch with Toto as has my plumbing supply store from which I purchased it. This saga has been going on for 3 weeks and I need advice as to whether there is anything else that might be causing the problem.
From the beginning the toilet kept dripping. Initially, it was a slow drip, ever 15-30 seconds, but it would eventually taper off after and 1-2 hours. I had read all about how you can hear the water drip in a unifit, but 1-2 hours later seemed excessive. Tank water level did not appear to be dropping (even with the water suppy to the toilet turned off), but it was a very slow leak. Several days later the leak became non-stop and the tank level did drop, the fill valve kept kicking in, etc. In the meantime, the fill valve started making loud sucking/groaning noises. Toto to their credit agreed to send new parts....fill valve and flush valve.
Got the new parts installed and the toilet still slowly drips into the unifit for hours after flushing. So far the leaking from the tank seems to have stopped and the fill valve sounds normal. We also checked whether the toilet was level front to back and not tilted which could contribute to water leaking over the weir, but the level is perfect. In speaking with Toto about the continued dripping, they agreed that it was not normal. They are working on a new version of the unifit itself (not the toilet) and are willing to have that installed, but it is still in production and won't be ready for at least 2 months. One of the changes in the design is to deal with the dripping noise sound. Apparently, Toto is aware that there can be extensive dripping into the unifit past a short period of time after flushing.
It was also indicated to me that the installation of unifit toilets takes more precision than other toilets and one suggestion was to have the plumber reseat the toilet on the unifit by a 1/4 of inch, but then that suggestion was withdrawn. (Must say, the toilet appears seated on the unifit in a fairly snug manner from what I can see and feel with my hand so that there isn't a lot of play, but this isn't my area of expertise.) I was told that Toto has seen situations where some folks have 2-3 of the same unifit toilet installed, 2 of the toilets don't drip, the 3rd does extensively.
Toto has said that if I don't want to wait for the new unifit, I could pick out a different Toto toilet and have it swapped out, but I should not pick a unifit toilet if I don't want to have the potential drip issue. It was not made clear, however, about whether I could recoup the financial difference between the cost of the Guinevere and a non-unifit toilet.
I am having a hard time understanding why a newly designed unifit will stop the dripping. I understand that they are trying to deal with the noise, but regardless of noise, why should water keep dripping from the bowl for several hours. Do all toilets do this, but we just don't hear it with the non-unifit toilets? I keep thinking that something else must be going on, e.g., a defect in the porcelain itself or the weir.
I picked the Guinevere for numerous reasons, including how it fit into the space I have available and it had the latest double cyclone technology for bowl cleaning on top of flush power. It looks great in my 100 yr old house.
I need to make a decision soon about swapping the toilet out and finding one that will suit our needs or waiting til the new unifit is available. Before making up my mind, I thought I would throw my problem out there to see if any one had run into this before and/or had any other thoughts or suggestions of what might be going on and what we could try. My apologies for the length of this post, but I wanted let folks know all that has been tried and what I have been told.
I appreciate any and all help. Thanks in advance.
