Only a small quantity of Toto toilets use the Uni-fit adapter. If it does, it comes with the standard 12" version, and 10, or 14" versions can be purchased. The adapter essentially contains the trap. On the Promenade, you can clearly see the trap cast into the porcelain. All Toto's that can use this are skirted models like the Carlyle, Vespin (I have one of each), and several other models. Not all skirted models use the Uni-fit, either (the Aquia is skirted, but uses it's own design). This adapter ONLY works on Toto toilets designed for it.
Toto Vespin II CST474CEFG with SS114 Softclose seat.
This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
Installation was by James Love of Love Plumbing & Remodel 206-949-5683
In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
Everything is on the truck for that.
The Vespin comes with a standard 12" adapter or you can order a 10" or 14" adapter depending on your rough-in distance.
