TravisJJ
Hello!
I know this has been talked about before, but I cannot find anything specific to my set up. First off, I have an Orbit #57256
Can you let me know if there's any additional steps I should be taking? Here's what I've done so far -
First, I turned off my sprinkler system.
Then, inside my home, I turned off the main water valve here:
Then, outside my home, I opened this water valve to let water drain out here:
After this fully drained, I closed the water valve.
Then, I flipped the below black lever on each of my 6 station valves which manually turned each station on. I left each of these on until water stopped blowing out of each station.
Then, I put the above black levers back to where they are.
Then, I turned these (solenoids) on each of my 6 station valves to let air inside:
Is there anything else I should be doing inside or outside?
Thank you in advance for your replies!
