Help!! My Wife is going to FREAK!!!
Discussion in 'HVAC Heating & Cooling' started by Gregmo24, Jun 13, 2009.
  1. Gregmo24
    Gregmo24 New Member
    Jun 13, 2009
    I promised my wife a new fancy LCD thermostat so I went out and bought a Lennox ComfortSense 7000 (since I have a Lennox HVAC system) to replace my Honeywell Chronotherm III.
    My problem is that when I removed the Chronotherm from the wall, I discovered that my home only has a 4 wire configuration to run my HVAC system: Red (R), Blue (Y), Green (G), White (W). I tried to use the same configuration with the ComfortSense thermostat but it would never power up. I used the following configuration Red (R), Blue (C), Green (G), White (W) and it powered up, but wouldn't cut on my AC compressor.
    When my wife finds out that I bought an expensive thermostat that can't even cut on the AC she's probably going to want to kill me. :eek:
    What can I do?
    The ComfortSense has the following wire terminals:
    - C (Common 24 Vac)
    - Y1 (1st stage heating or cooling)
    - Y2 (2nd stage heating or cooling)
    - B (Heat Active reversing valve)
    - O (cool active reversing valve)
    - W1 (1st stage heating)
    - W2 (2nd stage heating)
    - G (Fan Relay)
    - R (24 Vac Power)
  2. Cass
    Cass Plumber
    Nov 12, 2005
    When all else fails read the directions...were there directions with it?
  4. Cookie
    Cookie .
    Oct 7, 2005
    I am just curious does she look like her mother?
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Post the spec's on your Lennox HVAC system; not all systems take all 'stats.
    http://www.hvacmechanic.com/tstatwiring.htm
    Better yet, post a schematic [which may be found online or pasted inside a panel].
    I think the Correlation Coefficient between 'stat changeout problems and
    the wife's appearance
    is around 0.00001 but Cookie might be onto something, anyway.
  6. Cookie
    Cookie .
    Oct 7, 2005
    You bet I am. Anytime, a man is afraid of his wife, I wouldn't want to meet her mother. :D
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    I was using tongs to pick out bagels at the supermarket, when out of the corner of my eye I saw a woman walk up to me at great speed and then stop short.
    Probably I was supposed to flinch.
    I ignored her, so she said "EXCUSA ME!"
    I said "You're excused."
    She seemed to be of Asian origin.
    But she wasn't done with me.
    She said "IAMINAHURRY!"
    I put on my best snarl, faced her and said "SO AM I."
    She stood there a while longer during which time I calculated where to hit her to cause maximum demotivation without drawing blood.
    Blood draws crowds, Master Kim taught me.
    http://www.kim-studio.com/AboutUs/grandmasterkim.html
    She left.
    I don't know where these women come from. Are they born or made?
  8. Cookie
    Cookie .
    Oct 7, 2005
    Both. I have this supermarket near me, where one cannot go to on Sundays. This one Sunday my husband and I forgot. Your story reminded me of this alot.
    My husband and I are very agreeable people. To a point.
    So, there we are, pushing our cart through this store and it was progressively getting harder and harder through the increasing amount of people coming in.
    Well, we were polite enough. We would wait before moving our cart in someone's way, we made sure we weren't hitting someone shins with it, but, it was getting to be too much for my husband.
    He said to me with an urgency to his voice, " I got to get out here before I punch someone's lights out."
    Honestly, at that point I couldn't understand it, even though I knew it was annoying.
    Then, about a month or so ago, I forgot and headed up there on a Sunday. Now, of course, I am alone. He is gone.
    So, I am milling through the store, and then, all of a sudden this wave of anger came over me, one too many times, I got shoved with the cart, got banged into, the skin came off my shins, old women grunting at me, old men, being rude to me, you get the point, then...
    I lost it.
    I threw my hands up in the air! PUSHED my cart into a pile of people saying, " KEEP IT."
    I left. I knew I had to honestly, before I punched someone's lights out, lol.
    People can really get under your skin.
  9. Cookie
    Cookie .
    Oct 7, 2005
    Buy your wife this outfit and she will forgive you,
    [​IMG] ha ha ha ha ha ha, lol.
  10. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I'd switch to geothermal heating/cooling.
  11. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    It should be
    Red (R) to R
    Blue (Y) to Y1
    Green (G) to G
    White (W) to W1
  12. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    But that still leaves one wire missing in order to power the thermostats display. It might work or it might be intermittent.
    One thought would be to trade off the green fan control wire and use the green wire for the (C) common signal.
    This "(C) to green to (C)" wiring would not let you manually turn on the fan, however the fan would still come on by itself as needed.
Similar Threads: Help Wife
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling Help! - new system is not cooling adequately Jul 14, 2016
HVAC Heating & Cooling Looking to buy 2 stage 17 seer AC Need Help Jul 5, 2016
HVAC Heating & Cooling Mini-Split help Jun 10, 2016
HVAC Heating & Cooling Honeywell 9000 Series Thermostat Installation Help Apr 19, 2016
