Help Me Understand
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jamjar, Mar 10, 2008.
  1. jamjar
    jamjar New Member
    Mar 10, 2008
    Hello, and thank you in advance for your advice. I would like the drain in my tub to be replaced. Just the beauty ring? and the part you see down to the cross piece. Can this be done? Is is that complicated? My husband is not sure how to do this, I told him I would find out!! Ok, you can lol now, but I will take your advice!! Thank you:D
  2. jadnashua
    I don't know if those are generic. They make a spud wrench to fit over the cross-bars and unscrew it. You're less likely to break them off if you use one, but still no guarantees. The gasket should probably be replaced at the same time and put some plumber's putty under the new piece (unless it is a fiberglass tub). It might require a new drain...
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    [​IMG]
    It can be a can of worms that may lead to replacing the waste & overflow. Use a Dumbell Wrench to try unscewing it first and hope it works.
  5. jamjar
    jamjar New Member
    Mar 10, 2008
    THANK YOU:D:D
  6. jamjar
    jamjar New Member
    Mar 10, 2008
    THANK YOU:D:D:D
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Dumbell wrench
    [​IMG]
  8. hj
    drain
    The trim ring may unscrew easily, or it could require that it be cut out. There is no way to tell until you try it. If it needs to be cut out and you persist in trying to unscrew it, you will probably snap the pipe under the tub and have a major repair job on your hands.
  9. jimbo
    jimbo Plumber
    http://www.watcomfg.com/WATCO/Downloads/WatcoPriceGuide.pdf
    See the QuickTrim kits on page 17, and the NuFit kits on page 18. These allow a quick and easy update of tub trim without getting into possible difficulties. They just snap in, or glue in, to the existing shoe. I have a NuFit on my own tub, over a year now, and it is fine.
Similar Threads: Help Understand
Plumbing Forum, Professional & DIY Advice help understanding code - drains Dec 27, 2014
Plumbing Forum, Professional & DIY Advice Plumbing sink with no overflow. Please help Thursday at 9:02 AM
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Tuesday at 3:53 PM
Plumbing Forum, Professional & DIY Advice Chipped shower tile....what to do help!! Monday at 6:09 PM
Plumbing Forum, Professional & DIY Advice HELP PLS - Drainage for Filtration and Softener System Feb 16, 2017
