JosephG
This does not look correct to me and I want to replace above ground PVC with galvanized pipe. If you look at image 145206 you will see two pipes being fed off the main. The one in the center feeds a 3 bedroom home and adjacent landscaping and the one on the left feeds a couple of acres with faucets and drip irrigation. Also, the sand filters. What do you think about them? Should I replace them or keep them? I have zero plumbing knowledge but I have lots of experience! ;-) That said, the only part I can claim credit for in these photos is the ball valve. There were so many leaks and breaks when I got this place a few months ago, that installing the valve seemed necessary. Thank you in advance for any help you might provide.
