Yes Iron bacteria will clog up the impellers. The clogged impellers will still build the correct max pressure, they just can’t let through the proper flow rate. The impellers are heavy from the extra material, which is why the amps do not decrease with the flow rate.
I think the spinning action of the impellers even accentuates the buildup of materials. With the pump spinning 10,600 RPM compared to a normal pump at 3,450 the material probably clogs even faster.
Yeah you will probably never get those impellers unclogged with a shock treatment, but it is worth a try. Maybe if you shock on a regular basis you can get to it before it becomes too thick for the shock to work.
