Help installing toilet flange
Discussion in 'Toilet Forum discussions' started by lordmoosh, Mar 31, 2013.
  1. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The issue is the existing closet bend with the heel inlet. Getting rid of that and cutting in the wye is fine- as long as the sink is properly vented. If it is not vented, the sink's trap can get siphoned every time you flush the toilet.
  2. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Ok, thanks!
  3. Terry
    Aug 17, 2004
    So the advice of a working plumber is not good, but Jim the Retired Defense Industry Engineer's is.
    I can't tell you how many thousands of jobs I've had permitted and passed. :)
  4. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Hi Terry,
    Jim responded the fastest and has more posts than you. Clearly he must be at a higher level. :p
  5. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    I forgot to ask. I've read that there are cheap AAVs to avoid. What would be some brands/models that have a good track record?
  6. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    WHOA, Guys!! I read Jim's comment about the "toilet fitting" just to mean that you didn't want to keep running it into the heel inlet, not that he was saying that Terry's suggestion of a wye was wrong!! I don't think I have ever seen Jim purport to contradict Terry. In fact, he often passes on offering advice where it gets into codes and the technicalities of plumbing; indeed, he did that earlier in this very thread.
  7. jadnashua
    All I said was you don't really want it going into the existing heel input...is that wrong?
  8. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    You guys are being too serious. We were just JOKING. Jim is very helpful. :)
    Can anyone recommend good brands/models of AAVs? Any brands/models to avoid?
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The only one I have ever installed was an Oatey® Sure-Vent®.
  10. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Hi all,
    I just finally got time to start doing this (finally almost done spackling/painting the bathroom...). I bought a donut as suggested by Terry and all. It is a 4x3 donut.
  11. jadnashua
    Measure the ID of the hub. Go to www.fernco.com and look up what you need.
  12. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    There is nothing on there website that I can find. I will try contacting them. Thanks.
  13. jadnashua
    In looking at the picture...a donut will NOT work on this...it is NOT a hub! You need a reinforced connector to go from the CI to PVC. Essentially, you'd make connections as if it were the existing hubless CI, but need the connector to convert from the CI to PVC, which have different ODs. I think what you need is listed here http://www.fernco.com/plumbing/shielded-couplings/proflex-couplings model 3000-33.
  14. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thanks I was going crazy with the donut.
  15. jadnashua
    Drainage pipe is spec'ed as INTERNAL diameter...if the OD is 3.75, the ID is likely 3".
  16. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    The inner diameter of the cast iron hub is 3.75"
  17. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    I did the plumbing today. The model 3000-43 was the correct item to use, it fit perfectly.
  18. Terry
    Aug 17, 2004
    You're fine.
    Done, wrapped up, good to go.
  19. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thank you all for your help!
  20. jadnashua
    Yes, but he didn't have a hub, he has hubless CI, so the outlet of the Y is the same diameter as the rest of the pipe!
Similar Threads: Help installing
Toilet Forum discussions Porcher Veneto: Need help installing Piston Jul 9, 2016
Toilet Forum discussions Need help installing 3x4 lead drain pipe on 3" steel pipe Mar 15, 2015
Toilet Forum discussions installing 6" backflow valve on drainage help. Oct 18, 2014
Toilet Forum discussions Installing a toilet Help Jun 8, 2013
Toilet Forum discussions Need help installing American Standard Boulevard Luxury Toilet Seat Mar 25, 2013
