Help identifying shower valve
Discussion in 'Shower & Bathtub Forum & Blog' started by Santa C, Jan 22, 2009.
  1. Santa C
    Santa C New Member
    Jan 22, 2009
    New York
    Hi all. My name's Chris. Thanks for all the useful info I've gotten while lurking in the forums.
    I'm remodeling my bathroom but left the existing shower valve in place. The closest I can find appears to be similar to a Kohler 303-k, but mine looks slightly different. I'm hoping the Kohler Coralis will fit since that's the only decent looking trim I can find that looks like it might work. The last shot is what's left of the old diverter. I'd greatly appreciate any help.
    (I should've looked for a brand/model number before I closed the wall, but didn't realize it would be an issue at the time).
  2. jimbo
    jimbo Plumber
    Looks like a Kohler Trend ( pre-1980). Pics of handles would help. Will try to find some part numbers.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    you got to be kidding
    you got the wall already open,
    you have perfect access to change out that 40 year
    old odd ball Kohler faucet
    the parts you are looking for are probably
    not available (its Kohler remember)
    it would be wise to put in a new Delta and save yourself a lot of greif...down the road
    what exactly is stopping you......
  5. jadnashua
    You obviously didn't get this job inspected...a tearout and replacement of the shower normally requires a permit. This type of remodel almost always requires bringing the system up to current code which means an anti-scald valve. Sometimes you luck out, but finding trim for an old valve is often tough.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It's sort of like finding repair parts for a Yugo. If you do find them and install them, you still have a Yugo. The hard part of the job is already done. You have the wall open with access to the valve. Get a Delta valve and the trim of your choice and live happily for many years to come.:D
  7. Santa C
    Santa C New Member
    Jan 22, 2009
    New York
    Thanks for your quick replies. I took pictures of all the plumbing and wiring for future reference before I closed up the walls, but they're closed now. I haven't grouted the tile yet though, so if it's going to be a nightmare finding trim, better to rip it out now I guess. I'd like to leave it if at all possible though. Jimbo, I threw out the handles during demo. Jad, I wasn't planning on doing a shower tearout, just new wall finishes/shower trim. That is all existing plumbing in the pics. Thanks again.
  8. hj
    handles
    IF it is Kohler, and the pictures indicate it might be, then handles are the easiest thing to replace. Many Kohler valves use the same size handles.
  9. Santa C
    Santa C New Member
    Jan 22, 2009
    New York
    Thanks HJ. I'd like to use the Kohler Coralais trim (best of limited options), but it says for use with k-303-k valve only. If that's the case, are the stems for the Trend & 303-k valve interchangable? If so, I could probably swap-out the stems to accomodate the Coralais trim.?
  10. Santa C
    Santa C New Member
    Jan 22, 2009
    New York
    So I got the Kohler Coralais trim but the handles do not engage the hot & cold stems. There is a gap of about 1/4" from the tip of the stem to the serrated inner portion of the handle (not sure what this part is called). I'm trying to find a way to extend that inner portion but have been unable to find that part. Does anyone know what that piece is called? Sound feasible? Thanks in advance.
  11. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Kris Kringle,
    I'd take that wall down in a heatbeat and correct the problem of not replacing that valve.
    You are looking for nothing but problems down the road.
    You are already just starting to see them.
    Take it out and install a new pressure balanced or, thermostatic valve and enjoy your bath upgrade!
  12. Santa C
    Santa C New Member
    Jan 22, 2009
    New York
    Thanks for your reply. I guess it'll be worth it the first time I don't get scalded when my wife decides to run the water in the kitchen.
Similar Threads: Help identifying
Shower & Bathtub Forum & Blog Help identifying brand to find parts. Oct 9, 2016
Shower & Bathtub Forum & Blog Need help in identifying Roman tub faucet from late 1980s Oct 5, 2016
Shower & Bathtub Forum & Blog Help identifying shower diverter stem Sep 23, 2016
Shower & Bathtub Forum & Blog Help Identifying my shower valve. Sep 8, 2016
Shower & Bathtub Forum & Blog Nibco Series 600 unit Help identifying shower valve/trim Sep 6, 2016
