Help identifying Moen shower trim kit
leubanks83
Nashville
I have a home that was built in 1984, and now I cannot find the brand to the shower to replace the trim kit. I got an estimate on replacing the shower valve, but that was way too expensive. I have to believe I can find a trim kit that matches this one. Any help? Or does anyone know where I can research to find this?
You have the older Moen Chateau shower trim. All hardware stores carry this trim.
This Moen is from 1978
The cartridge on the left is a 1200 which is still a good replacement. I normally use the 1225 on the right.
They make a T473 trim with a crystal handle or the TL473 with the lever handle.
leubanks83
Nashville
I thought it was a Moen, but Home Depot's Moen trim kits didn't have the screw holes in the right place. None of them lined up. Neither did Lowes. Are there any good online retailers to look for this? Thank you so much for your help!
Chad Schloss
USA
This should be it at Home Depot
Model # 9D00010001
Internet # 202562814
Store SKU # 464830
DANCO Trim Kit for Moen Tub/Shower Faucets
here's one from homedepot that is labeled chateau:
MOEN Chateau Single Handle Trim Kit for Posi-Temp Shower in Chrome
Jimbo
San Diego, CA
There are 4 basic Moen valve/trims : Chateau teardrop shape handle, flat plate ( this is yours ); Legend round handle, bowl plate; Moentro, teardrop handle, bowl plate, screw holes different; Positemp..larger teardrop handle, plate similar to Moentrol, but handle and stop tube diameter larger.
You should stop doing business with any store which cannot supply all four of these VERY common parts.
leubanks83
Nashville
Thanks, I'll see if I can find those. I was really hoping to find an oil rubbed-bronze trim kit.
All the ones labeled "Moen Chateau" seem to be Chrome or Brushed Nickel. All of the Moen oil rubbed bronze trim kits seem to be labeled Kingsley and Brantford. Is there some master catalog where I could find an ORB Moen Chateau trim kit? I've been scouring web sites for hours, but none of the ORB ones have the Chateau listed, so I'm worried I'll order something that won't work.
Thank you guys for the help.
Model # 9D00010001
Store SKU # 464830
Internet # 202506437
Store SO SKU# 477898
leubanks83
Nashville
Also, how can I tell whether Chateau trim kits will fit mine since apparently mine is push-pull? Most of these don't say! I wish I knew more about this stuff!
Chad Schloss
USA
http://www.moen.com/consumer-support/faq
you have a standard, non pressure balanced valve.
A recent innovation now makes it possible to retrofit Moentrol trim to standard valves. Service kit number 145058 (shown below) can be ordered to make the change. (from the above page)
edited: you have the standard valve, not the posi-temp one i thought it was.
leubanks83
Nashville
How did I not find this on their web site? Thank you so much.
you have a posi-temp (standard, non pressure balanced )valve. look for trim that fits the posi-temp valve, not the moentrol valve.
OR:
Chad Schloss
USA
it says it fits moentrol valves. i would look for whatever you want that fits a moentrol valve & then get just the trim and get that adaptor plate. i've never used it. i'm just a diy'er, maybe the plumbers will respond to this in a bit.
Jimbo
San Diego, CA
When you want to replace trim for a valve which has been out of production for probably 10 years, your trim options become very limited. Chrome is in. Maybe some brushed nickel, the second most asked for trim finish. Any of the bronzes.....good luck, but Danco or one of the other aftermarkets may even have that one.
You will likely NOT be able to use a bowl-shaped Moentrol trim. Your valve is too close to the finished wall surface. But worth a try.
leubanks83
Nashville
Thank you everyone for the words of wisdom. I'm new to this DIY lifestyle. This is my first home, so I know I have a lot to learn.
I ordered the service kit and the Kingsley Moentrol trim kit.
One follow-up question:
There is some gray plastic on top of the valve. I assume that was to make it flush with the finished shower. Do I need to remove that gray plastic before attaching the service kit adapter to the valve? Or does the adapter go on top of the gray plastic?
The gray plastic is there to prevent the tile guy from going right up to the valve. It can be thrown away. It serves no purpose now.
Hackneyplumbing
Homeowner
Alabama
Its also a thin wall mounting bracket/support. It stays on the valve and supports the fiberglass from behind. Sounds crappy.....yep I agree. LOL
Midwest
I'm in this sane situation today. After much research, I come to understand I have Standard Moen valves (1986). So I need to install a Moen 145058 adaptor. Great. Now a need a trim kit to switch from antique brass to chrome. My kitchen designer sold me a T181...which is a Positemp trim. I was going to return it but does it make a difference? Doesn't a Standard Valve + Moen T145058 support ANY 7 in trim? Moen is trying to force me to three Moentrol trims which are totally no to our liking.
This reply seems to imply any trim will work in my case. Thoughts?
