Help identifying DWV pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by CM2304, Jan 8, 2012.
  1. CM2304
    CM2304 New Member
    Dec 20, 2011
    Pennsylvania
    I'm in the midst of a project and I was all set to go with 3" Schedule 40 fittings for the vent and drain pipes, but as you can see by the photos, the OD of the existing 3" pipe is slightly smaller than new standard Schedule 40 3" pipe that I was prepared to use. Is anyone familiar with the type of DWV pipe in the pictures? Are fittings available for the type of pipe I have or do I have to adapt the existing stuff to Schedule 40?
    BTW - Thanks for this great forum.
  2. hj
    It is probably SDR pipe which, because of the thinner wall and the need to maintain an actual 3" i.d., means the o.d. has to be less than the standard sch. 40 pipe. The only fittings I have ever seen for it were bell and spigot push tight style and they were ONLY used outside a building underground. There are "bushings" which adapt it to standard pipe size fittings.
  4. jimbo
    jimbo Plumber
    One of those is not sch. 40, I suppose. Here is a portion of a chart showing the OD of pipe ( ID of fitting would be in the ballpark
    What are the measurements of your pieces?
    Schedule 40
    [TABLE]
    [TR="bgcolor: #990000"]
    [TD="class: whitehead"] Nom. Pipe Size (in)[/TD]
    [TD="class: whitehead"] O.D.[/TD]
    [TD="class: whitehead"] Average I.D.[/TD]
    [TD="class: whitehead"] Min. Wall[/TD]
    [TD="class: whitehead"] Nom. Wt./Ft.[/TD]
    [TD="class: whitehead"] Max. W.P. PSI**[/TD]
    [/TR]
    [TR="bgcolor: #FFFFFF"]
    [TD]1/8"
    [/TD]
    [TD]0.405
    [/TD]
    [TD]0.249
    [/TD]
    [TD]0.068
    [/TD]
    [TD]0.051
    [/TD]
    [TD]810
    [/TD]
    [/TR]
    [TD]1/4"
    [/TD]
    [TD]0.540
    [/TD]
    [TD]0.344
    [/TD]
    [TD]0.088
    [/TD]
    [TD]0.086
    [/TD]
    [TD]780
    [/TD]
    [/TR]
    [TD]3/8"
    [/TD]
    [TD]0.675
    [/TD]
    [TD]0.473
    [/TD]
    [TD]0.091
    [/TD]
    [TD]0.115
    [/TD]
    [TD]620
    [/TD]
    [/TR]
    [TD]1/2"
    [/TD]
    [TD]0.840
    [/TD]
    [TD]0.602
    [/TD]
    [TD]0.109
    [/TD]
    [TD]0.170
    [/TD]
    [TD]600
    [/TD]
    [/TR]
    [TD]3/4"
    [/TD]
    [TD]1.050
    [/TD]
    [TD]0.804
    [/TD]
    [TD]0.113
    [/TD]
    [TD]0.226
    [/TD]
    [TD]480
    [/TD]
    [/TR]
    [TD]1"
    [/TD]
    [TD]1.315
    [/TD]
    [TD]1.029
    [/TD]
    [TD]0.133
    [/TD]
    [TD]0.333
    [/TD]
    [TD]450
    [/TD]
    [/TR]
    [TD]1-1/4" *
    [/TD]
    [TD]1.660
    [/TD]
    [TD]1.360
    [/TD]
    [TD]0.140
    [/TD]
    [TD]0.450
    [/TD]
    [TD]370
    [/TD]
    [/TR]
    [TD]1-1/2" *
    [/TD]
    [TD]1.900
    [/TD]
    [TD]1.590
    [/TD]
    [TD]0.145
    [/TD]
    [TD]0.537
    [/TD]
    [TD]330
    [/TD]
    [/TR]
    [TD]2" *
    [/TD]
    [TD]2.375
    [/TD]
    [TD]2.047
    [/TD]
    [TD]0.154
    [/TD]
    [TD]0.720
    [/TD]
    [TD]280
    [/TD]
    [/TR]
    [TD]2-1/2"
    [/TD]
    [TD]2.875
    [/TD]
    [TD]2.445
    [/TD]
    [TD]0.203
    [/TD]
    [TD]1.136
    [/TD]
    [TD]300
    [/TD]
    [/TR]
    [TD]3" *
    [/TD]
    [TD]3.500
    [/TD]
    [TD]3.042
    [/TD]
    [TD]0.216
    [/TD]
    [TD]1.488
    [/TD]
    [TD]260
    [/TD]
    [/TR]
    [TD]3-1/2"
    [/TD]
    [TD]4.000
    [/TD]
    [TD]3.521
    [/TD]
    [TD]0.226
    [/TD]
    [TD]1.789
    [/TD]
    [TD]240
    [/TD]
    [/TR]
    [TD]4" *
    [/TD]
    [TD]4.500
    [/TD]
    [TD]3.998
    [/TD]
    [TD]0.237
    [/TD]
    [TD]2.118
    [/TD]
    [TD]220
    [/TD]
    [/TR]
    [/TABLE]
  5. jimbo
    jimbo Plumber
    I am suspicious of the color,, grayish rather than white. This can mean it was inferior quality, made with a lot of regrind, instead of virgin PVC resin. Was your house built by a cut-rate builder?? What did they use for water supply??
  6. CM2304
    CM2304 New Member
    Dec 20, 2011
    Pennsylvania
    The house is 40 years old and was built by a very reputable builder that is still in business. The OD of the gray pipe is 3 1/4". The pipe is branded "Evanite" and it's PVC 1. I don't think it's junk at all - it's just different. The white pipe in the photo is a regular, brand new schedule 40 coupling.
  7. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Well since the "Evanite" doesn't say sch. 40 on it, I woudln't assume it was ...
  8. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The ASTM number would lead you to the standard the pipe was manufactured under.
    It is not on the list of authorized materials for indoor plumbing in my state.
  9. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    http://gsi.nist.gov/global/docs/vps/csfiles/cs_219-59.pdf
    That pipe and fitting was not around for very long. It was 3.25" OD, about 2 years later everyone standardized on 3.50" for 3" DWV. It's a durable pipe, just doesnt match today's ASTM standards.
    Remove it if feasible or use a Fernco to adapt I guess.
  10. jimbo
    jimbo Plumber
    WOW....good job bringing up that standard from 1959! Who KNEW????
    The ASTM spec ( D1784) just specifies the material, not the size schedule. I don't know what the " 2 X 4 " means, but the bottom line as we deduced it that it is not sch. 40. I would contact a plumbing supplier to see if adapter bushings are available.
  11. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    it probably means it will fit into a 2x4 studded wall. it is probably old schedule 30 pipe. Look up schedule 30 PVC fittings and you can transition from those to schedule 40 pretty easily. Here are some schedule 30 fittings and pipe made by Genova. start on page 41 of the PDF file.
    http://genovaproducts.com/docs/PlumbingCatalog.pdf
  12. hj
    It APPEARS that sch. 30 fittings would work, but good luck finding any. I have NEVER seen anyone stock either the pipe or fittings during my 60+ years in the business, nor have I EVER seen an installation using that type of pipe or fitting.
  13. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    go to big orange. it's there. our whole house is plumbed in schedule 30. apparently it is ok to use it for new construction here, back in 2004 anyways.
  14. cad-cat
    cad-cat plumber/piping designer
    Jan 11, 2012
    piping designer/cad draftsman
    Chicago area now 44 years in michigan
    i was seeing alot of sch. 30 being used back in Michigan before i left. talk about loud drains.
Similar Threads: Help identifying
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Help identifying faucet brand! Dec 17, 2016
Plumbing Forum, Professional & DIY Advice Help identifying kitchen faucet? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Bathtub faucet, Help with identifying old trim Dec 1, 2016
Plumbing Forum, Professional & DIY Advice Need help identifying baseboard Sep 2, 2016
