Cleanout cap broke while being removed. Looking for a replacment, if one exists, but need help identifying cleanout cap and where to possibly get another.
Please excuse my misuse of terms, but I'll try to describe what I'm dealing with.
Pipe/Tee side has a tapered flange. Cap side has 2 pins which tighten against the tapered flange when turned. Rubber gasket on the cap which creates a face seal against the pipe/tee. I don't see any threads on either side similar to the other cleanout plugs I'm seeing online and in hardware stores.
Home was build in the early 70s. I believe the pipe is cast iron. The cleanout cap might be brass. Pipe diameter is appx 4".
Thanks
Thanks
