Help identify my 3-handle tub fixture?
Discussion in 'Shower & Bathtub Forum & Blog' started by mc510, Dec 18, 2009.
  1. mc510
    mc510 Member
    Dec 18, 2009
    El Cerrito, CA
    I hope folks here can help me to identify the bathtub fixture in my "new" (to me) 1950 home. It looks like a basic Price Pfister job, including the PP Beaux Art escutcheons and handles, but I need to identify it real specific so that I can locate a correct packing nut for the diverter handle.
    I guess I should explain the situation, then describe the fixture. So, the diverter handle has no packing nut on it. Needless to say, water gushes out. The really special part is that some genius has packed a huge amount of grout in around the bonnet so that it's impossible to remove. So I need to find the correct packing nut, but I can't take the whole stem in to the hardware store with me. What I can do is remove the hot and cold stems (not grouted in place ... thank you, previous homeowner!), and I've attached a picture of one. Now here's the thing that's making me crazy: the packing nut from the hot and cold does not fit on the diverter ... the diverter appears to have a slightly smaller thread.
    I've taken the hot stem to every store in town, told my story, and gotten nothing but shrugs. Everyone says that all 3 packing nuts should be the same size. I'm starting to think that I'm crazy, but everytime I play with it I come away convinced that the diverter thread is indeed smaller.
    Okay, so that's my story. Anyone have any idea what I'm looking at here? Thanks in advance.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Chip the grout out with a small chisel. We do it all the time. Just use light taps with the hammer it will come out. Then replace the hole stem. It is a Price Pfister and the packing nuts are different.
    John
  4. mc510
    mc510 Member
    Dec 18, 2009
    El Cerrito, CA
    Thanks John ... so the grout in there isn't unheard of? I was afraid that someone packed it in there to try to stop a leak that was hard to reach.
  5. hj
    stem
    I have never heard of anyone selling just packing nuts for faucets in the first place. I have never checked, nor had to, but as far as I know all three PP stems use the same nut. I will have to look at them when I go out to my truck later.
  6. mc510
    mc510 Member
    Dec 18, 2009
    El Cerrito, CA
    well, i was able to buy just a hot/cold packing nut at a well-stocked local hardware store, but it doesn't fit on the diverter. But anyways, I'd be happy to replace the whole diverter stem, as long as it's safe to chip away the mortar that's packed into the wall cavity all around the bonnet. Johnjh2o1 says it's common, but I'm still a little skittish of chipping it away without knowing what it's doing there in the first place. Is this standard or at least common, and what's the grout doing there?
  7. Terry
    Aug 17, 2004
    Mortar around the valve doesn't do anything.
    There is now way a bit of grout is going to hold 60 PSI of pressure.
    Chip it away so you can get to the valve to repair it.
  8. mc510
    mc510 Member
    Dec 18, 2009
    El Cerrito, CA
    Thanks everyone, I will do as you suggest and chip out the mortar so I can remove the whole stem. I'm still curious why it's there, though ... why would a competent plumber mortar-up the diverter bonnet?
  9. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    That was done by the tiler.
    John
  10. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    My guess is that the plumber didn't do it. It was probably the tile setter that got it in there because the protective sleeves were not on the valve when he grouted. :)
  11. hj
    hole
    Some characteristics of tile setters are:
    1. If the hole does not have to be "neat", such as around a stem under a trim ring, they will cut it perfectly as close to the valve or pipe as possible.
    2. If it does not have to be "watertight", or the part will have to be removed someday, they will pack the hole with grout.
    3. If it does have to be neat, and watertight, such as behind the tub spout, they will use a hammer to make the hole and leave it ungrouted.
  12. mc510
    mc510 Member
    Dec 18, 2009
    El Cerrito, CA
    hey guys, thanks for all your advice; big help! I was able to chip out the grout and remove the diverter stem; it wasn't easy to find a replacement but I finally did, and now everything is working again (and not leaking).
Similar Threads: Help identify
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog Can anyone help identify this Shower Faucet? Oct 21, 2016
Shower & Bathtub Forum & Blog Help identifying brand to find parts. Oct 9, 2016
Shower & Bathtub Forum & Blog Need Help identify in order to replace Thanks! Oct 6, 2016
Shower & Bathtub Forum & Blog Need help in identifying Roman tub faucet from late 1980s Oct 5, 2016
