mcminnville
Hi All,
Was wondering if I could get some opinions on what to install. I have been pitched with products from Water-Right, Culligan, Kinetico to name a few. Everyone claims to have the "best" solution.
I would like to have a system that is simple, reliable, and serviceable by many (not proprietary).
Here are the water test results from an independent lab:
PH: 7.6
Hardness: 22 gpg
Iron: .3 ppm
Manganese: .125 ppm
No bacteria or other issues.
It is new construction and I have the well water pumped into a covered 1,500 gallon holding tank, then pressurized, then split into irrigation and household use. I need to treat the water after it comes out of the holding tank. Water pressure and volume for the water treatment equipment is not an issue. I would also like to achieve a normal flow rate of at least 12 gpm and a peak flow rate of 15-18 gpm.
I know I will need a water softener towards the end of the treatment cycle. I could probably run a greensand filter prior to water softener to take care of the iron and manganese but this would kill my flow rate and force me to use pot perm. Is there a better way????
Many thanks!
PH: 7.6
Hardness: 22 gpg
Iron: .3 ppm
Manganese: .125 ppm
Many thanks!
