Help - guidance on recessed lighting
Cubfan_Mark
Good afternoon - I am finishing my basement, 9' walls, and I plan to install a suspended ceiling at about 8', so I don't have to build soffits around ducts, etc. So there will be about a foot difference between my floor joists and my suspended ceiling.
I notice they have both new construction and remodel recessed light housing. The new construction I could used and attach to the ceiling grid (if I read the box correctly) and the remodel appears as though it would just sit on top of the ceiling tile.
Can someone recommend which type would better suit my situation, and also recommend which name brand (Halo at Home Depot, Thomas at *******, etc) housing will do the job.
Drick
Any new construction cans will work fine. You can let them sit on top of the grid before you start installing the panels. After you cut the hole in the panel for the recessed light put in THAT panel and then use some small sheet metal screws and attach the can to the track. Obviously you can't easily remove the panel with the light in it after this, but it makes for a strong can installation. (The small screws used for metal stud walls work great if you already have some.)
-rick
Mattbee24
Fremont, OH
If you have access to them, Juno new construction can lights are great for suspended ceiling installations. They have notches on the bar hangers specifically for the ceiling grids.
Cubfan_Mark
Thanks for the feedback. I do have access to the Juno lighting.
I am thinking about the 5" or 6" cans with an open trim. I also want to put these on a dimmer. Is there a light bulb recommendation, as I am using this for general lighting needs.
Thanks.
Ian Gills
Senior Robin Hood Guy
USA
I'll have to do this eventually. Can anyone remember how many square feet a 60 watt can will cover?
I will need to work out how many I need to buy when I get round to installing a ceiling.
