Help eliminating glare on worktable from overhead fixtures
Discussion in 'Electrical Forum discussion & Blog' started by AcidWater, Dec 15, 2012.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    I have a 4x8 work table that's used for all sorts of activities. The ceiling is not too far above it; the joist bottoms are 4'10" but hanging a light puts the bottom of the fixture more like 4' 4" above the table.
    I get glare when placing coated paper (magazines, etc) on the table.
    I've got 4' fluorescent fixtures with a white plastic diffuser. Tried hanging them down the center of the table, and just now moved them so one is along each edge. Still get glare. The location where the glare reflects from changes when I move my body; it seems to be a certain angle of reflection. If I tilt the object a little to reduce make the angle from table to my eyes closer to 90 degrees the glare goes away.
    Aside from wearing polarized sunglasses, what can be done to locate the fixtures to get rid of glare?
    Is there some specialized diffuser that I could get?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    My dentist's office has wall-mounted fluorescent fixtures which are pointed up at the white ceiling, and the light reflects down. I was thinking of using something similar in some areas of my house.
  4. AcidWater
    AcidWater Member
    Oct 14, 2008
    Need to illuminate the TABLE not the walls. Bouncing off the ceiling only works for a high ceiling. Basement is less than 8' high.
  5. hj
    Put the lights over your head so the light reflects away from you. Place them where you will not be in your own shadow, however. If the surface reflects light into your eyes there will ALWAYS be a glare.
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    You might try experimenting with some Fresnel lenses. In a lighthouse or an overhead projector, they are used to direct a mass of light into a beam...but flip them over and they spread it out and diminish hot spots.
  7. jadnashua
    Reflective surfaces like your glossy paper will always reflect things. The angle of incidence is equal to the angle of reflection...basic physics. Lights directly over the table WILL reflect directly back up - it's like a mirror. You need to sidelight things to bounce the light away from your eyes, but still illuminate the subject matter. But, that will potentially bounce it into your eyes as well...you may not get a choice of too many positions where the light is right.
  8. AcidWater
    AcidWater Member
    Oct 14, 2008
    Forgot to mention that there are people all around the table, so can't use a light behind one person.
    I've seen business lighting sights talk about their techniques; diamond diffusers, polarizing filters, etc.
Similar Threads: Help eliminating
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Lost one leg of power need help. Aug 4, 2016
Electrical Forum discussion & Blog Desperate for help with flickering issue May 15, 2016
Electrical Forum discussion & Blog Help with load calculations... sanity check Mar 15, 2016
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Feb 12, 2016
