HELP! Draining a washer?!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by newmanr, Sep 20, 2005.
  1. newmanr
    newmanr New Member
    Sep 20, 2005
    I really need some guidance. We are rebuilding our detached garage which sits about 6 feet below (elevation) and 25 feet away from the sewer line connection under the house (raised foundation). Our property is a fairly gentle slope. Here are my questions, please help!:
    (1) Does code require us to drain the washer into the sewer line or can we simply drain the washer into our garden? (The former owners did this) We live in Pasadena, California.
    (2) If we have to drain to the sewer line . . . is it possible to connect the drain to a sump pump and pump the washer water back up to the house line. It would require a run of approximately 30-40 feet and elevation increase of about 6-8ft.
    (3) Is there another way to resolve this issue.
    THANK YOU!
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
  4. newmanr
    newmanr New Member
    Sep 20, 2005
    Can you clarify?
    I looked at the sump pump you recommened . . . but will it pump the drained water on a run of 35-40 ft. with an elevation increase of 6-8ft?
    Also, is it against code to drain into a garden?
    thanks.
    ryan
  5. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    a) should pump it just fine
    b) Yes, it is against code to drain your washer into the garden
Similar Threads: HELP Draining
Plumbing Forum, Professional & DIY Advice Need help draining sink in garage Sep 12, 2015
Plumbing Forum, Professional & DIY Advice HELP! Previous owner was draining washing machine into sump pit. No drain. (pics) Jul 17, 2013
Plumbing Forum, Professional & DIY Advice Need help in draining/venting a new bathroom layout Apr 9, 2008
Plumbing Forum, Professional & DIY Advice Toilet, tub, and sink draining very slowly. Need help! Sep 29, 2007
Plumbing Forum, Professional & DIY Advice slow draining tub, help! Sep 6, 2006
