Help diagnosing a well pump that runs every 10 minutes
Johnd3452
Type of pump?
Submersible___Yes_____
Two wire (no control)________
Three wire (control box)__yes____
Wire Size__12 gage_______ Wire Length________
or
Jet Pump (above ground)_________
One or two pipes down the well__one__
Size of Pump?
Motor Horsepower?__________
Pump Model #______________
Date Pump Installed__________
Pumping from?
Cistern tank___________
Pond, lake, river________
Water Well______yes______
Depth of well__________
Depth to water_________
Pump Setting__________
Pipe Size______1___"
Drop Pipe Material
PVC________
Steel_______
Poly________
Well Recovery Rate_______gpm
Well Casing Diameter___6____â€
Rock Well__________ Sand Well__________ Other______________
Date Well Drilled____________
Well Casing Material
PVC________ Steel___yes______ Other_________
Pressure Tank?
Bladder or diaphragm tank (one pipe to tank)_____yes_____
Size or model of tank_____42 gal_______
Air charge in top of tank, with pump off and water drained____________PSI
(check with car tire gauge)
or
Plain Hydro Pneumatic tank (two pipes to tank, one in and one out)_________
Size of tank________________
Pressure Switch Setting?
On 30, off 50 ________
On 40, off 60_________
Other_____on 30 off 45__________
Pump Control Method?
Cycle Stop Valve model #_________
Variable speed control #__________
Pump Start Relay (sprinkler timer, no tank)__________
Manually turned on and off____________
Pump Protection
Cycle Sensor_________
Pumptec_____________
Low pressure cutoff switch (lever on side)__________
Other_______________
Filters or Softeners____softener after the pressure tank__________
Before or after pressure tank_______
Type of filter___________________
Bypass available______yes__________
Water Used For?
House Use___yes____ Number of baths___1____ Number of People___2_____
High Flow Showers_______gpm?
Plus/Or
Irrigation with timers________
Irrigation with hoses________
Heat Pump______gpm?
Problems Experienced
No Water_________________
Water only part time________
Water at all times but weak_____
Air in water_______________
Pressure surging___________
Water Hammer (noise)______
Too Much pressure_________
Other____pump turns on every 10 minutes when pressure drops_______________
Pump makes clicking or buzzing sounds________
No Sounds______________
Pressure gauge reading________psi
Other____________________________________
Do you have, and know how to use
an Ampmeter and Voltmeter____yes______________
Describe Problem___
My well pump is turning on every 10 minutes.
When the pump turns on I watch the pressure gage and see the pressure rise to 45 psi and then the pump turns off.
The pressure immediately drops from 45 psi to 40 psi.
Over the next 10 minutes the pressure drops from 40 to 30 psi.
At 30 psi the pump turns on again.
I turned off the supply line into the house and the pressure stays at 40 psi.
My diagram:
pump in the well--->supply line--->shut off valve--gage--tank--switch--->water delivered to house
close here
This lead me to look for leaks under the house which I found and repaired two.
Unfortunately the symptoms are the same.
I don't see a check valve inside the house or under the house. I assume there is one at the pump?
Suggestions?
Thanks,
John
