Help diagnose problem with Dual-flush Toilet
Discussion in 'Toilet Forum discussions' started by hank755, Dec 31, 2010.
  1. hank755
    hank755 New Member
    Dec 31, 2010
    Canada
    Hello,
    I bought a Glacier Bay Toilet from my local Home Depot and installed it with no problem. When I opened the water supply line, the tank started to fill but then stopped after an inch or two. It seems that the water is leaking through from the tank to the bowl and down the drain. This toilet does not have a flapper. Instead it has a plastic cylinder that looks something like this:
    http://image.tradevv.com/2010/09/10/nicoleher_1536319_600/toilet-repair-kit-dual-flush-valve.jpg
    [​IMG]
    I know for flapper toilets, water leakage is a result of the flapper being blocked from closing. But I don't know much about this cylinder contraption.....
    I have re-read the instructions a dozen times and made sure I installed all the parts properly. The tank had all the parts in it so I didnt touch it. I also made sure the rubber sealing gasket is installed properly between the tank and bowl.
    Does anyone have any ideas?
    Thanks
    Henry
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Glacier Bay says it all...
    Nothing like a cheap Home Depot House Brand made in China by the lowest bidder.
    Go down to Home Depot and ask if they have replacement parts for it...
    On second thought don't bother... They don't!
    Do you have the booklet that came with the toilet?
    If you do it has a parts breakdown with the part number you need to order and a phone number to call.
Similar Threads: Help diagnose
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions Help: Trickle sound and smell from Cimarron Jan 21, 2017
