Help changing shower cartridge
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by theboneman21, Jan 31, 2014.
  1. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    Hi there.
    So I have a leaking faucet and it whistles when I turn it on part way; when open full blast whistling vanishes.
    I am going to check the washer and the seat as I suspect the seat might be worn and chewed through the washer.
    I took a very cursory stab at it this morning but I could not get the cartridge out. I tried a regular wrench and vice grips.
    I put some oomph in it but didn't want to come onto it too hard for fear of breaking something or stripping it totally.
    Is there a specialized wrench that would work for the cartridge and/or is there a way to loosen it up ?
    It is a waltec, not sure the model number, but it has two washers around it if that helps narrow it down.
    Thanks in advance for any and all tips
  2. hj
    I noise at partial flow usually indicates a worn washer with a "feather edge" acting like a reed in a musical insturment. Without seeing the faucet there is no way for use to tell you how to remove the stem.
  4. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    s
    Ok
    Turns out it is Waltec 76100
    The only part that protrudes from the housing is the stem thing and the hexagonal face part.
    I have tried an adjustable wrench but admittedly I don't know how hard to come onto it. The house is 22 years old and I am not sure if these were ever changed so there could be rust and/or calcium buildups.
    Just wondering if there's a best set of tools to use and maybe some lubes like liquid wrench or something ?
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I don't know about your stem, and I don't know whether you want to turn clockwise or CCW -- I expect is the same way you turn the handle to turn on the water.
    However the best way to not strip a hex head is to use a 6-point socket or a 6-point closed-end (box) wrench. You would probably need a deep socket to clear that stem.
  6. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    It turns counter clockwise, and they can be pretty stiff. I can get them with a crescent wrench.
  7. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    Are any lube products worth a darn ?
  8. hj
    quote; Are any lube products worth a darn ?
    I couldn't tell you because I have seldom used them in my 60+ years repairing faucets.
  9. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    Ok thanks
    I was just paranoid about coming onto it and stripping it. Lots of iron and calcium in this area and i have no idea how long they've been on there
  10. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    ok
    so it is still leaking slowly
    i replaced the cartridge and seat. i wrapped tape around the threads of the seat. the whistling sound is gone but the leak is still there.
  11. Terry
    Aug 17, 2004
    I would not of used tape on those threads. It's too easy for a strand to get under the faucet seal.
  12. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    ok
    i will remove the tape and see what happens
  13. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    o so that seems to have kinda worked.
    it was dripping at a rate of about a drip per second. now it is every 10 seconds or so
  14. jadnashua
    While it is apart, you need to look at the valve seat (the part the washer pushes up against to seal the flow). If that is also worn or scratched, even a new washer won't seal it well. On many, that seat is also removable and replaceable, but it takes a (inexpensive) tool to remove it.
    FWIW, on straight threads, you never use tape to seal it...that is only used on tapered plumbing threads to fill in around the threads, creating the seal.
  15. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    i changed the seat too
    anything i might have done incorrectly? i realize that is a silly question since you cannot see
  16. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    there is a cold knob and a hot knob and the shower pull handle thing to send water from the spout (bath mode) to the shower. The things are all in line above the spout which is centered under the shower activation handle thing.
    the drip is from the spout
  17. Reach4
    Sep 25, 2013
    I am wondering if the remaining drip is not from the other side, or maybe even residual water draining from the shower for a good while.
  18. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    you may be right on one of those. i changed the hot and the drip is cold
    now i am guessing it is either the cold has a drip too or, like you said, it is residual so it is cool NOW.
    unless the leak is so minute it is cooling along he way
    i probably wont get a chance to check it until tomorrow; two showers plus a bath coming up for my family tonight.
    if it is still dripping when i get up tomorrow morning i will consider getting replacement parts for the cold side. even if it is not a cold water leak, the look of the seat in the hot water side that i changed tells me should probably change the cold anyway because the hot was pretty ratty
  19. Terry
    Aug 17, 2004
    It takes 35 minutes for a tub spout to quit dripping after a shower.
  20. theboneman21
    theboneman21 Member
    May 30, 2013
    New Brunswick
    then it definitely must be the cold leaking as its been over 1.5 hrs.
    so i will take a stab at it tomorrow, just need to find out what kind of cartridge i need for the cold
  21. Reach4
    Sep 25, 2013
    Except that the threads that drive the washer may be the other way, don't you think it will look like the hot? I would suggest just changing the washer and maybe the seat, rather than getting a cartridge.
Similar Threads: Help changing
Plumbing Forum, Professional & DIY Advice Moving and changing shower valve help Sep 17, 2008
Plumbing Forum, Professional & DIY Advice Toilet 16" rough in help Wednesday at 7:55 PM
Plumbing Forum, Professional & DIY Advice Fleck 5600SXT Program help Tuesday at 6:58 PM
Plumbing Forum, Professional & DIY Advice Stuck U-Pipe slip-nut help Monday at 7:08 AM
Plumbing Forum, Professional & DIY Advice Help identifying shower faucet brand Mar 18, 2017
