HELP - Broken Pipe Under Tile
Discussion in 'Shower & Bathtub Forum & Blog' started by mostgold, Dec 14, 2008.
  1. mostgold
    mostgold New Member
    Dec 14, 2008
    Hello,
    I would like to ask the forum what it the best way to handle the following plumbing repair.
    It appears that a feed line pipe for our Roman bath spigot broke just below the bathtub tile. I've taken off the spigot and can feel the broken pipe just below the tile level. I've attached links to three (3) photos of the situation. Note the missing spigot in between the faucets where I have removed it.
    Where should I cut into the tile..from the top where the faucets and spigot are OR from the side inside from the shower stall.
    Photos can be seen at: http://picasaweb.google.com/stevenhg/Plumbing?authkey=zuMZ-Mjt5bA#
    Thanks in advance for any advice you might have.
    Steve
    steve_goldberg@comcast.net
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    You may have to cut into it from both places. I would start at the top.
    You should be able to remove the tiles fairly easily using either a grout rake or a dremel with a tile bit.
    Do you know what is under the tiles? Cement board? Wood? etc..
    Another approach is to use a right-angle grinder with a diamond wheel to cut into it. That would be the best way to cut into the cement board, as well.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
Similar Threads: HELP Broken
Shower & Bathtub Forum & Blog Shower diverter broken! Need help identifying model. Danze "Parma" Jul 30, 2013
Shower & Bathtub Forum & Blog Broken Valve stems, need to replace! Help! Oct 29, 2010
Shower & Bathtub Forum & Blog HELP - Broken Pipe Under Tile Dec 14, 2008
Shower & Bathtub Forum & Blog Bathtub Problem.....Help!! Broken Screw!!! Jun 18, 2007
Shower & Bathtub Forum & Blog Help appreciated! : stripped Moen retainer pin / clip Today at 5:32 PM
