Help! Best way to fix leaky well pump line coming into basement - leaking now.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by msc1504, Sep 30, 2010.
  1. msc1504
    msc1504 New Member
    Sep 30, 2010
    Balttimore, MD
    Ok so looking at the 2 attached pictures I am trying to figure out the best way to fix the leak coming from where my well water supply comes in through the base concrete block wall of our rancher.
    It seemed sometims during heavy rains theres was a slight amount of water, but I live in Maryland and we are in the middle of floods not seen for a long time and this is the first time I ever saw water this much.
    Just been mopping it up every few hours.
    I was thinking of having miss utility mark for underground lines (although i dont think there are any) dig from the outside and put some waterproof concrete or something???
    We also just had big trenches dug in our yard for geothermal HVAC and i wonder if that made it worse. Also wondering if there is anything i can do in the short term. perhaps put something on the inside? Now that i look at it, it looks like the previous homeowner new there was a leak and applied some newer concrete sealant or whatever.
    Thanks for any advice,
    Matt
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    I would dig down to the foundation on the outside and check your perimeter drains with a camera to make sure they are working. Then use tar sealant on the wall.
  4. msc1504
    msc1504 New Member
    Sep 30, 2010
    Balttimore, MD
    Jerome, how big of an area would you apply tar sealant? if the pipe is perhaps 1.5" PVC, would you go like a foot around or pretty much just where the pipe comes through, also would a modular home from the mid 70s have perimeter drains? It just seems like everything in this house was done halff a$$ by the previous and original owner. Thanks.
  5. Jerome2877
    Aug 25, 2009
    Well if you don't have any perimeter drains then I would be surprised you havn't had more problems with leaking basement walls. Where do your rain leaders go? Are there floor drains in the basment and if so where do they go? The tar sealant should be on as much of the outside wall as possible. However the water needs to be able go somewhere. When you dig it up check the line for leaks as well, could be a pinhole leak in the pvc where it penitrates the wall.
  6. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    You can't seal a leak from inside! I suggest that you dig down to the hole/pipe on the outside and at least a foot all around. seal around the hole with some tar or good sealant (not cement). Then I would locate a well driller or well pump supplier (not big box stores), and purchase a 50# bag of "Hole Plug" or equivelent (probably less than $17.00). They will know! Place the hole plug in the hole (dry) and cover it back up with soil. When it gets wet it will swell and should seal any future leaks around the pipe.
    I'm sure the ground is saturated from all the rain and flooding in your area.
Similar Threads: Help Best
Pumps and Tanks Well Forum & Blog. Water is life. Help designing the best well system?? May 9, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Well pressure tank help. Yesterday at 3:44 PM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Feb 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Cistern Help 2 Feb 12, 2017
