ShanPE
Hi - new to this forum, but I have been searching through it over the last month and have seen some great responses and advice. We have an 18 year old home on a shallow well system. Last month we noticed that our well pump was on constantly and never shut off. Shortly after, we started losing water pressure and the pipes were sputtering out air by times. The problem was worse upstairs - we live in a split entry and the pump is located in the basement. When my husband tested pressure at the well pump (1/2HP Gould's jet pump - can't remember the model, but they no longer make them) it was really poor. So we purchased a new pump (3/4HP gould's) and replaced the old one. At first everything seemed fine. Our water pressure is great throughout the house. However, last week we started getting sputtering again - sounds like air in the lines as the toilet is refilling, etc. When we shower, you can hear air, but pressure is fine. We thought perhaps the filter was just clogged as replacing the pump and our issues from before had disturbed some sediment. So, my husband replaced the filter. That didn't help - we are still getting the air sounds. The new pump seems to be working fine and the pressure is steady in the house and at the pump. It seems the problem is somewhere between the tank and the house. Could there be a problem/clog somewhere in the lines? Does it make sense that our pressure is still okay even though we can hear air?
