68cst
Trying to determine the best size water softener for my conditions. This is my 1st attempt at water treatment so I'm learning on the fly. Any input/advice is greatly appreciated!
The house was built in 2012 and is on chlorinated city water. I don't currently have a water softener installed but is plumbed for it....a 1" PEX loop in the garage adjacent to the water heater.
Here are the particulars:
http://www.qualitywaterassociates.com/sizing.php
When I plug in my numbers (10 gpg, 4 people, 60 gals/day/person) I come up with 2,400 grains capacity per day and 19,200 total grains capacity which allows for weekly regeneration with 1 day reserve capacity. These numbers result in the calculator recommending a 1.0 cu ft system.
My question or concern is that if I just slightly increase either my water usage per day or the hardness number, it re-calculates to a 1.5 cu ft system. (just going from 10 grains to 11 or increasing water use from 60 to 65 gals/person).
This leads me to believe that a 1.0 cu ft system is borderline for my circumstances and would be operating close to the threshold of it's capacity given our water usage and condition.
Am I thinking correctly? Would it be best to go to either a 1.25 or 1.5 cu ft system?
I'd also appreciate any feedback or advice pertaining to valve selection. I'm leaning towards the Fleck 7000SXT since it seems to be somewhat higher end than the 5600 and supports the higher flows of the larger capacity systems.
Thanks for your time.
Eric
- 4 people - 2 adults, 2 kiddo's
- 2.5 bathrooms, one of the showers has 2 spray heads, no body sprays
- Water usage really is 60 gals per person (240 gallons per day, actual from water bill's)
- Hardness - 10 gpg
- Iron - undetectable
- pH - 8
- Highest flow I measured is at the tub filler which is 5 gpm
Eric
