Heil furnace blowing fuse on board
Discussion in 'HVAC Heating & Cooling' started by pitteach, Mar 20, 2010.
  1. pitteach
    pitteach New Member
    Jan 14, 2008
    Hamburg, NY
    I have a 5 yr old Heil forced air 75k btu, 92% furnace that is blowing the 5 amp fuse on the control board. There is a low humming sound coming from the board and the transformer is warm, but when I install a new fuse and throw on the power, it pops immediately. This happens wether or not the t-stat is calling for heat or not. The led trouble code is not showing (obviously). The furnace has worked fine and nothing has been done to it-it just popped all of a sudden. I am suspecting the transformer, but how can I check or are there any other ideas?
    Thanks
  2. jadnashua
    While the transformer might be bad, it is more likely that there is a different failed component somewhere on the board or that the board drives that is overloading the circuit causing the fuse to blow. The fuse, on a well-designed board, will blow before the whole thing burns up. Unless you're lucky and can identify the part that is bad, you'll probably have to replace the board. Now, depending on how good the schematics are that they provide (often not very complete), and the troubleshooting guide is good, and (that's a lot of ands), you might find something off-board that is bad that is overloading the power supply on the board and blowing the fuse.
  4. pitteach
    pitteach New Member
    Jan 14, 2008
    Hamburg, NY
    I just jumped the t-stat at the board with a new fuse and she fires right up. The t-stat wire is ancient so I will replace and check out the thermostat as well.
Similar Threads: Heil furnace
HVAC Heating & Cooling New heil furnace odor Jan 2, 2008
HVAC Heating & Cooling Heil DC90 flame rollout tripping Jan 20, 2017
HVAC Heating & Cooling Heil Central Air Conditioner Jul 11, 2016
HVAC Heating & Cooling Rheem furnace model r92pa not lighting all the time Jan 24, 2017
HVAC Heating & Cooling Chattering Furnace Contactor Jan 7, 2017
